![]() | Home > My Defender > 1988 Shire Blue Landrover 90 Restoration |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11015 ![]() ![]() |
Good bit of progress there Dinnu
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
Just remember it's the work that pays the bills to allow you to do this fantastic restoration!!
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3572 ![]() ![]() ![]() |
You are so right James. Not just time is required !
Spent a couple of hours cleaning the engine block. Quite a bit of deposits came out. I honed the bores... unfortunately some areas at the top end of the stroke did not hone so well - I have the 3 legged honer not the ball type. I hope still good, as did not want to hone too much. I cannot really feel a ridge, so should be ok for the rings. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge A bit of paint later, engine block looking nice again. Target was to get dirty today, so can spend some clean evenings playing with the bottom end of the engine. ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3718 ![]() ![]() ![]() |
Nice work as always.
Thank you Co1
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Some progress today.
Piston oil coolers installed. Crank installed on new shells and thrusts. Getting the rear bearing cap on was a bit of a fight without the proper guiding blocks for the T shaped seals.. but in the end got there. Rotating the crank found some 'hard spots' ![]() ![]() Click image to enlarge Can shaft is installed on original journals. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Time well spent Dinnu on cleaning the block and then starting to put it all back together
Yes Clayton, best way to spend some time.. at least in my nerdish opinion 😂
Still a few more parts to clean... but for now I will try to assemble whatever is already clean 😉 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I would be the same way, can't beat the items being clean and then you can have a good look and then asses them
Black Puma Member Since: 31 Jan 2015 Location: Sydney Posts: 222 ![]() ![]() ![]() |
Love this build/rebuild Dinnu. Thank you for sharing. Don't rush, because I can wait to see this build unfold
Thank you Black Puma. I am actually getting worried about the rush/no rush thing, as I already purchased the tyres
![]() Bit more progress.. Getting the first piston ready to install. Pistons are not genuine. The genuine ones were quite expensive, and my reasoning was that if genuine crack, then might as well spend less.. and worse case is they crack as well and buy another set ![]() ![]() Click image to enlarge ![]() Click image to enlarge The timing case is almost ready to install. This timing case has 3 gaskets. One that goes around, to tentatively keep the oil in. There is another gasket just behind where the tensioner goes, and there is another gasket for the coolant. Strangely enough, they have different thicknesses... so very baffled. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
It is getting together. Looking more like an engine now... will not break any land speed records, but I will take good care of it, and it will get me there.
The sump has seen some better times... need a lot of TLC to get it look good again. That will be for another day. And will get the cover and bracket at back side of the injection pump painted at the same time. ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Great progress Dinnu, does look like an engine now
I had done the painting of the sump and a few small brackets, so Christmas afternoon while family was watching some movies, I entertained my self with this:
![]() Click image to enlarge Better than watching another Christmas movie 😂 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
