Home > Td5 > Injector Loom
cocker
Injector Loom
Hi guys i need a new injector loom is it best to go genuine Land Rover ?
Thanks
Post #932254 2nd Dec 2021 10:53pm
barbel jim
I do Thumbs Up every 2 years regardless
Post #932257 2nd Dec 2021 11:12pm
Why so often? I had the well-known oil problem on my Disco2 with the original harness after about 3 years from new, but after sorting out the replacement to solve the problem properly it has been fine for over 16 years.
Post #932260 3rd Dec 2021 12:01am
landy andy
I replace mine every few years, just to make sure no problems. I buy genuine LR one, but the pop the cap off the internal connector and fill with sealer, to stop oil migration.
Post #932262 3rd Dec 2021 12:13am
barbel jim
Peace of mind really. I’m sure I read somewhere years ago they were a service item? Originally I did have one fail, no oil in the red plug but down to 4 cylinders, and have just routinely changed it every couple of years since.
Post #932264 3rd Dec 2021 6:34am
When I built my 110 back in 2010, I had a used engine in it from Porny, it already had about 70k miles, so I sprayed the back of the plug with brake cleaner to de-grease it and then just smeared plenty of tigerseal all over it.
It's been fine (touch wood) ever since.
Post #932267 3rd Dec 2021 7:49am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Original one, but I have good experience (more than 10 years on my own cars) with "repair" of the looms - remove loom from engine, press the connector contacts a bit, to make them tight, replace 2 o-rings on the connector from head out, to stop engine oilleaking into cables.
Some cheap looms were working only for few weeks - the pins in connectors were made from too thin or soft metal. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #932296 3rd Dec 2021 12:32pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Re: Injector Loom
Thanks
I bought a Britpart loom from Paddocks and posted it here a few years back with photos of the connectors and construction details.
All experts on D2 concluded it was an original loom in a plain box with all appropriate TTE connectors and wire markings and identical to the Genuine Land Rover item. That was a few years back though.
Patrick
Post #932493 5th Dec 2021 2:42pm
x13pow
United Kingdom 2004 Defender 110 Td5 XS DCPU Auto Java Black
Thats one part i do not mind getting a non genuine item as i changed it with each oil change just because its a cheap enough part not too!
Post #932734 7th Dec 2021 3:03pm
markb110
As I have my ecu mounted on the divider behind my head, I wonder if I should make a sump for the loom.
In the 11.5 years of ownership I have only changed it once about nine years ago……perhaps gravity is on my side….. Whistle
Post #932740 7th Dec 2021 3:47pm
roel
I changed it in 2009 when I bought it. I had oil in the loom and ecu. So with the sale came a new injector, engine loom and a ECU.
I sealed the connector off the injector loom and no problems yet. My ECU is placed on the bulikhead between the seats as high as I could get with the original engine loom. Only the difflock wire had to be extended. Roel
2003 90 Td5 (2009-now)
Post #932819 8th Dec 2021 12:00pm
hydraulic_landy
Germany 2003 Defender 110 Td5 CSW Bonatti Grey
11 years w/o problems
As mentioned above, 11 years without problems.
I bought my Defender (my2003) in 2010 with 85000km on the clock, since last week (189000km) I realiced misfire and less power.
And at the plug was black oil. Sad
I had an idea: additional to the typical tasks like new loom and connectors at the 7 wires close to the ecu plug I removed the rubber seal in the red plug and drilled a few small holes in the red ECU connector, to give the oil an easy way out of the plug. pics are attached
Oilless wishes from Germany
Peter
Post #938205 18th Jan 2022 6:22pm
rallysteve
I generally buy the OEM branded ones rather than genuine. The last one I bought came in a Britpart box but was a proper OEM spec Leoni loom with the ITT Canon branded connector.
I have previously returned an 'OEM' one however which was not the correct spec.
Cheers,
Post #938215 18th Jan 2022 7:05pm
Procta
what is the part No for this? i will change mine on the next service, Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #940114 30th Jan 2022 4:02am
hydraulic_landy
Hi,
the loom part number is AMR6103
you should also exchange the gasket for the rocker cover, thats LVP000020. The gasket could be differend, depending on the My
Peter
Post #940120 30th Jan 2022 6:48am
