Home > Off Topic > Dent removal
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Dent removal
The atmosphere at my house was a little awkward last night to say the least after one of my wonderful sons did this to my fire pit:
The dent is around 250mm long and the wall is deformed from top to bottom. Does anyone have any knowledge of dent removal or recommendations for a kit that can handle this type of dent?
Or even recommendations for someone in the huddersfield area that would remove it for me?
Thanks 2002 110 td5
Post #930560 21st Nov 2021 10:07am
markb110
Can you get a bottle jack and a couple of pieces of wood in there. Maybe a slow approach to putting pressure on the inside of the dent.
It might pop back without the need to hit it on the inside
Post #930563 21st Nov 2021 10:34am
Jimb1978
Hi,
I forgot to mention, it’s double skinned because it circulates air for a secondary burn so no access from inside. It is quite thin gauge stainless. Maybe around 1.5mm 2002 110 td5
Post #930566 21st Nov 2021 10:40am
kenzle8a
Glass moving sucker and pull gently on the outside, deduct relevant amount from child's allowance / trust fund etc...
https://www.amazon.co.uk/IMT-Suction-Grani...4&th=1
Post #930567 21st Nov 2021 10:55am
Jimb1978
Thanks. I might have one of those laying around somewhere, as you do!
To be fair on my kid, he was probably more upset with himself than I was. He knows how much I love my fire pit 2002 110 td5
Post #930568 21st Nov 2021 10:59am
Bluest
With it being stainless, it’s likely there’ll alway be evidence of a dent there, it doesn’t like being worked. As mentioned, I’d try sucker. Can you find a way to hold it so can put some force into it? 2007 110 TDCi Station Wagon XS
Post #930569 21st Nov 2021 11:02am
Jimb1978
I’ll see what I can rig up. I’ll try putting something heavy inside it. I’ll let you know how I get on 👍 2002 110 td5
Post #930570 21st Nov 2021 11:14am
LR90XS2011
if you struggle with a sucker but you have a hot glue gun, you could try to glue something to the outside to pull it with and then use a hair drier to get the glue back off. DEFENDER 90 TDCI XS,
Post #930572 21st Nov 2021 11:55am
Ianh
Perhaps having a chat with a local car bodyshop, they will be very used to pulling dents, albeit mostly on mild steel and then filling and painting. However they will have a range of suction pullers and I expect you will need a few strategically placed pullers that are simultaneously pulled to ensure the minimum of panel creasing is visible once the process is completed.
Post #930573 21st Nov 2021 11:56am
nitram17
Jimb1978 wrote:
Hi,
if the sucker doesn't work you might have to cut a hole in the inner skin to try the jack idea mentioned and then pop rivet a repair piece over the hole.im assuming a patch in the inner skin wont be noticed to much.
Post #930579 21st Nov 2021 1:18pm
Jimb1978
Thanks chaps. I’ll have a quick go with the sucker, but I’ll probably end up taking it somewhere for a professional to have a go at it. 2002 110 td5
Post #930583 21st Nov 2021 1:57pm
Jimb1978
I’d call the sucker technique a success in this instance. If the little creases left at either side still bug me, I might use a glue gun for a little localised tweaking.
 2002 110 td5
Post #930588 21st Nov 2021 2:53pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I used to have a dent removal kit which involved something similar, you glued loads of tags onto the damaged area and then attached them to a sliding hammer, it worked reasonably well on a double skinned section of a truck cab Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #930604 21st Nov 2021 5:08pm
LR90XS2011
Thumbs Up DEFENDER 90 TDCI XS,
Post #930609 21st Nov 2021 6:37pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
If you can pour a little fuel in between the skins and light it, the dent should pop out…. Whistle
And I’m only suggesting a little fuel… being teaspoon amounts (5ml) Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #930620 21st Nov 2021 7:56pm
