Home > Maintenance & Modifications > STC1346 - Vent |
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 |
17th Nov 2021 12:04am |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 848 |
Yep, they are the 'factory' ones. Hopefully someone can advise you on the correct position to mount them. 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
17th Nov 2021 6:40am |
Thanks Shroppy
Much appreciated I will order them this week just did not want to waste £82.00 with the postage |
17th Nov 2021 9:01am |
Ordered 2 there's 3 left i think if anyone else is after any see link in previous message.
17th Nov 2021 9:04pm |
Putting this in between them
https://www.wildernesslighting.co.uk/wilde...3093-p.asp |
17th Nov 2021 9:20pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
Weren't they the same part as fitted to Austin Maestro vans?
Seem to recall that they were deleted after a few years as they were prone to allowing water in. Having lived with an unlined hardtop I have to admit condensation is not a lot of fun but a headlining cures it completely. If you want a pure utility however then ventilation should help. ONE LIFE, GET IT! |
18th Nov 2021 9:41pm |
prone to allowing water in. That bit made me laugh as being in a Defender you would think condensation would not be an issue. whist searching about the vents on here I found an older post mentioning the Maestro.
My issue is wet tools and clothing being in the back from work and no heated window in the back door it soon fogs up which then would cause the headliner and other material to start to get mould on |
18th Nov 2021 9:51pm |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 716 |
Hi. I've got these vents in my '89 90. Did you want measurements of their position or are you just going to bosh them in? Instagram: l90andy
2006 Land Rover 90 TD5 CSW Silver Edition My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
19th Nov 2021 2:19pm |
Thanks I would love to have the measurements as trying to get most stuff looking as Land rover had done it
19th Nov 2021 2:30pm |
This is the RH one, measured down from the top of the roof and along from the roof seam. HTH
Click image to enlarge Instagram: l90andy 2006 Land Rover 90 TD5 CSW Silver Edition My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
19th Nov 2021 3:11pm |
That's great Andy much appreciated I will see how it goes with my decals on either side and get the vents as close as possible
19th Nov 2021 3:24pm |
No probs. They should be ok, the vents are only above the door section
19th Nov 2021 3:28pm |
Thanks again I will use your pictures for reference
19th Nov 2021 4:11pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6040 |
I filled mine in with mastic..... back of the 110 kept getting full of dust being sucked in.
21st Nov 2021 1:24pm |
