![]() | Home > Puma (Tdci) > Output shaft failure, Forum Survey |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Thanks for taking the time to clarify most appreciated
Whilst nothing is impossible I shudder to think what the development costs involved in this would be, and those costs would have to be paid for by the customer. I wonder how many "upgraded" transfer boxes would be sold if they were, say £12,000 a pop. Not many, I think. A lubricated joint (which remains clean and rust free) should cope for an indefinite mileage with a small amount of movement, since the destructive fretting will only take place in the absence of lube or the presence of abrasive. Personally (and as an engineer) I feel that a jointed shaft of this type is a preferable solution to a one-piece shaft, since any misalignment in the latter case would have to be taken up by flex in the shaft and is, I feel, more likely to cause collateral wear. |
The world of motoring certainly dodged a bullet when I decided not to become an engineer
![]() Is it that costly to recast an aluminium case and strengthen it to allow for some decent access to the output shaft to be created whilst it's in situ on the truck . Blackwolf as I respect your opinion ....given the information we have today what do you think is the best way to reduce the likelihood that your output shaft isn't going to go bang in the middle of nowhere..... In leaning towards the cheapest option by Ian series ..the grease nipple option as it appears if Ashcroft shafts are not wearing it must be the lubrication so Ian's solution gives you the lubrication and no leak or extra cost risk. |
My advice - buy a Puma that is known not to eat shafts, lubricate the coupling properly, and then guard the extension housing with your life (I believe that it is variability in the extension housing that is causing the misalignment, since there are countless thousand MT82 gearboxes and LT230 transfer boxes in other applications that seem to be OK - this is a new problem with the Puma and the only unique part is the housing).
If you already have the vehicle and it is a coupling-eater, my advice would be to check for alignment (Gloucesternige has shown one way this can be done) and keep testing adaptor housings until you find a good one. I believe that if you can set up the vehicle without alignment issues it really doesn't matter what type of shaft or coupling you have provided that any coupling is lubricated. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4317 ![]() ![]() ![]() |
Or just get an Ashcroft adapter properly fitted and not worry too much. it may ultimately be a sticking plaster, but it is well engineered and seems to be proven to substantially delay or even totally eliminate the issue. A periodic inspection of it, say every 50,000 miles (or prior to a major expedition) should be sufficient if you still aren't convinced. 2007 110 TDCi Station Wagon XS
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
47K miles on your blue kit = 2nd gen. no issues I'm going to take you at your word ![]() |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3599 ![]() ![]() ![]() |
Wear on the splines is also a function of the contact surface hardness.
Wonder if there was any attempt to case harden the splines. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I'm fairly sure that they are, certainly the outside of the shaft is.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
Several applications use male-female splined shafts and they run dry. eg splined shaft from CV cup fitting into a wheel hub on IFS and front wheel drive vehicles. Splines though are considerable longer. I have seen vehicles with many km and show no wear at all. Puma 110" SW
Any of them built by land rover and fettled by ford?The prevailing theory is that it's misalignment of the casing to .a couple of aftermarket companies believe they have solved the problem .I am reserve the right to be sceptical until we get anacdotal or scientific evidence from either of the companies that they have replaced the LR shaft with one of their own from trucks that have replaced their shafts at least twice in 50000 miles..........and their fix is going strong after another 50000 miles.
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 232 ![]() ![]() ![]() |
One of guys (independent LR mechanic) on the AULRO forum here in Oz posted regarding the hardness of the materials: “ The Ashcroft kit the material from memory is round that 50 in hardness on the Rockwell scale. The original adaptor floats around 20 - 25 on the Rockwell scale, which is too soft”. If true, could this part of the cause? |
It could contribute.. but lots don't have any bother at all!I'm going with. Mr plum holding a crooked shaft and casing in the garage as cheif suspect
I think it was on this forum, potentially on this thread too, that someone commented that it is always the female splines that wear? I do not know on how many shafts that info was based. Another improvement could be DLC coating? Commenting about a comment by Dave Aschroft - my 90 had the latest, red cover. I had to drop the TC soon after purchasing the 90 because of an oil leak. Mine was the 1/400 cases that had a poor installation. The female spline cup was damaged, the red anodized cover was cross threaded, quite a big part of the threads were damaged, and it was out enough to let oil pour out of the main gearbox (the cover was not engaged on the 2 O rings on the splined cup. Luckily I could save the cover, but had to replace the female splines as the splines on the gearbox mainshaft side were almost 50% gone. Since correcting, there were no oil leaks. ![]() Click image to enlarge ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
