![]() | Home > Td5 > TD5 coolant dropping in the expansion tank |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Have you still got the EGR system connected up or have you blanked it? If you have got it blanked, I would be tempted to just bypass the cooler with the coolant pipes. I did start looking into it myself and was going to revert back to the 10p/eu2 coolant layout which didnt have the cooler but never actually got around to it.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Done precisely the above, EGR bypassed, cooler removed, hoses bypassed and all is good. Simpler and less to go wrong.
Geobloke, did you just link the coolant pipes which originally ran to/from the cooler or did you reroute from the oil cooler to the radiator like the EU2 setup?
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
EGR system connected up as it left LR in 2006
repayment cooler on its way, next think is removing the broken 6mm stainless steel bolt from exhaust manifold with out having to remover it |
did cross my mined but a lot of road side stop and DVSA inspect past one two days ago defender with EGR removed and tamper with and £1000 bill and DVSA spent good 1hr removing engine covers so give a miss thanks |
Blimey.
Its going to sound a bit like dentist tomorrow just found micro air grinder in work shop and at 6mm broken bolt will be out
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
I removed the EGR cooler - my coolant leak was from the front of the fuel cooler. If that’s leaking you’ll see pink inside the driver side engine mount. Simple enough fix too.
Todays job too remover that 6mm snap bolt ended up removing exhaust manifold and drilling it out and re-taping so now down tools again awaiting parts but at lest exhaust manifold is good order
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3510
DVSA are stopping private cars to check the emissions gear? And they spent "a good 1hr removing engine covers" What engine covers? The TD5 has one engine cover that can be removed in under two minutes. lf the above is true, then anyone who has removed or bypassed the EGR system better fit it back on. Although ROW spec TD5's never had an EGR |
now just wanting for post and manifold nuts
DVSA are stopping private cars to check the emissions gear? And they spent "a good 1hr removing engine covers" What engine covers? The TD5 has one engine cover that can be removed in under two minutes. Seemed to be 1hr if your stuck in traffic just before dvas check not that i had anything not fitted or bypass and dipping fuel tanks for red dev |
Yes you do get them checking for
red diesel round here, and l guess Defenders are more likely to be stopped for that as traditionally they are owned by farmers. Plus with diesel being over £1.50 per litre, people might be tempted to use red diesel if they have access to it. |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
So refit the egr valve having removed the flap, and keep the blanking plate on exhaust end. All looks standard but not crappy egr. |
