Home > V8 > My V8 Swap (Toyota 1UZ-FE) |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 280 |
Hello All,
Thought I'd begin the thread early before all parts are in my hands. Got a few things to iron out and discuss before I get going anyway. Part List Winchester Gears TDI R380 w/ 5% taller 5th, HD Bearings + Cooler Winchester Gears 1.2 TDI Transfer Box w/ ATB Diff DW250iL Universal 250l/h external pump Ashcroft Adapter plate LOF 300tdi Clutch kit Speed Hut gauges (Eventually) Loom from Pheonix Engine Mangement (Link Extreme ECU) ----------------------------------------------------------------------------------------------------------------------------------------------------------------- I will slowly add to this thread as time goes on but it will be somewhat quiet for a while as I'm only purchasing parts and or making them at the moment. Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ Last edited by LJMARSDEN on 14th Sep 2023 4:12pm. Edited 5 times in total |
28th Oct 2021 1:18pm |
Made up a design for my fuel sender mount in the td5 tank
Thought I'd save the monies making one instead of using a standard LR item Will be using a length of corrugated plastic piping as the return feed It'll be just two 9/16-18" for the plumbing which should be big enough to feed the pump the WEMA sender has a standard SAE 5-hole pattern - Which I haven't seen before (Its split by 72 and 68 degrees... not a PCD) please make any suggestions as I'm no mechanic but do just have some engineering back ground Click image to enlarge Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
28th Oct 2021 1:24pm |
I've seen a few that'll fit with the standard hole size and black/ white theme, just the illumination is an issue at the moment.
Wema do their own, Duratec seem fine too at a similar price. both have black bezels too. And plenty of other aftermarket brands available. I don't mind spending the time to find the right one for me. Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
30th Oct 2021 11:23pm |
Picked up the Motor today:
Its a 97 1UZ non VVTI Getting just a little bit excited now... Click image to enlarge Will begin the strip down soon Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
12th Nov 2021 10:12pm |
Timbo Member Since: 15 Jun 2021 Location: west mids Posts: 135 |
Look forward to seeing some progress
12th Nov 2021 10:28pm |
Bit of a photo dump of my weekend by weekend progress...
Nothing fun or exciting - just stripping the engine down and rebuilding the top end. Still got to wait for Winchester gears to confirm an order for the box and TC. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
12th Dec 2021 9:35pm |
I've got to investigate that head, looks like its gotten quite hot. I reckon the headgasket not a channel being blocked at the minute. Luke Marsden
12th Dec 2021 10:50pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
There’s a lot of bits here! Stick with it.
13th Dec 2021 7:32am |
Will do GREENI Luke Marsden
13th Dec 2021 1:52pm |
Rather you than me mate! Look's fun and you've only just begun! Did you see pheonix selling off some prewired looms? I think they had one for the ls400
13th Dec 2021 10:56pm |
True Tim
And no I didn’t - I’ll have to have a look. Thanks for letting me know Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
14th Dec 2021 10:23am |
Likkle more progress made this weekend
I polished all 32 valves lightly, just cleaning them up and making the surface much smoother. Also lapped both heads too, that was fun… (still somewhat satisfying to be honest) Now my next plan or task is to source the loom and ecu, then we can get the engine running outside of a vehicle Click image to enlarge Click image to enlarge Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
19th Dec 2021 9:42pm |
Some goodies finally arrived.
Got the ECU/ Loom being sourced this month too. After that, in march I will be purchasing the adaptor plate and 2.8TGV Clutch. Then we're ready to take the car off of the road. Click image to enlarge Can't get over how good all this looks, Quality looks billiant from Winchester. Such a shame I won't be able to see it all when its in the car. Luke Marsden 06 V8 1UZFE Defender 90 Instagram: https://www.instagram.com/defender__v8/ |
9th Feb 2022 5:56pm |
Tidy! I still can't believe the R380 is longer than an M57 BMW gearbox but it obviously is as my bulkhead will testify lets see some action now mucker
12th Feb 2022 10:50pm |
