![]() | Home > Puma (Tdci) > Gearbox Oil/change |
http://www.defender2.net/forum/post19142.html#19142
http://www.defender2.net/forum/post19041.html#19041 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Castrol BOT 328 is GL-4
![]() ............................................................. Earth first. Other planets later |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Yes, same viscosity range and fully synth as Castrol BOT328, but GL-5. Puma 110" SW ............................................................. Earth first. Other planets later |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2680 ![]() ![]() ![]() |
Guys - I need a bit of help here! I'm just ordering the fluids for an early-life oil change.
Happy on Engine and Diffs (already got these in my Opie checkout waiting to buy). Not too confident on the Gear box or transfer box. Suggest I'll stick with (or as close to) manufacturer recommendation especially whilst in warranty. Transfer Box: The OPIE site recommends the Castrol product: Castrol Axle EPX 80W-90 (formerly EPX 80w-90) gear oil There's no data in my manual. Gearbox: Manual recommends Castrol BOT 130M - as others have stated - can't find it! Castrol Website says Syntrans Multivehicle 75W-90 OPIE site says Castrol Universal 75w-90 semi-synthetic gear oil (formerly Castrol Syntrax universal) Am I being overly fussy? At least on a R380 it was always MTF94...there's too much choice? Any ideas/advice please? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Tbox: 75W90 or 80W90 GL-4 or GL-5
Gbox: 75W90 GL-4 (not GL-5) that is all you need to know. Synthtetic last longer than mineral. Puma 110" SW ............................................................. Earth first. Other planets later |
Thanks, MK, that's what I thought having read the forum, but the Opie site says:
So Opie are recommending an oil for the Gearbox which meets GL5... Not sure I feel confident about buying it... Think I need to buy the GBox oil elsewhere... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I use Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil in the transfer box and Millers Oils CRX 75w90 NT Competition full synthetic transmission oil for the gearbox. As for the diffs I use either a generic gear oil (Molytex EP90), Millers Oils Classic Differential Oil 90 (Formerly Classic EP 90 GL5) or the Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil, all available from opie oils
Front diff : 1.7litres Rear diff : 110 = 2.26litres, 90 = 1.7litres Transfer Box: 2.3litres MT82 Gear Box: Initial Fill = 2.4litres GL4 Fully Synthetic, Service Fill = 2.2 litres HTH Brian. |
For the Gbox ask him any of these GL-4 oils:
Syntrans Transaxle 75W-90 Syntrans Multivehicle 75W-90 Fully Synthetic MTF Iīm sure they have Amsoil but they are expensive me thinks Puma 110" SW ............................................................. Earth first. Other planets later |
symmo Member Since: 22 Mar 2009 Location: BRISTOL Posts: 15 ![]() ![]() |
You can get the Casrol BOT oil from a Ford parts dealer.
Thanks all. Order at Checkout ready to place:
Castrol Magnatec 5W-30 A1 Fully Synthetic Engine Oil 8 Litres Castrol Axle EPX 80W-90 4 Litres (1.6 litres in each axle) Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil 3 Litres (Transfer Box, needs 2.3l) Castrol Syntrans Multivehicle 75W-90 Fully Synthetic MTF 3 Litres (Gearbox needs 2.4l) I'll order it on Monday as I want it to arrive on Wednesday...Already bought filter at my local LR dealer. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
I believe the "official" line is that a gear oil change needs 2.2l as the "full" capacity is 2.4l but 0.2l remains trapped inside - if I'm wrong please tell me (doing mine soon - using Motul Gear 300) ![]() But shout it at them in German because life is also terrifying and confusing... |
That is correct
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Hi guys,
I bought mobil mobilube 1 shc sae 75w90 fully sysnthatic oil for both gear box and transfer case. The spec says, Mobilube 1 SHC 75W-90 meets or exceeds the requirements of the following industry and builder specifications: API GL-5/MT-1 ZF TE-ML 07A Scania STO 1.0 Mobilube 1 SHC 75W-90 has the following builder approvals: JSC AVTODIZEL YaMZ Gearboxes MAN 341 Typ E3 MAN 341 Typ Z2 MAN 342 Typ M3 MB-Approval 235.8 ZF TE-ML 02B/05B/12B/16F/17B/19C/21B Mobilube 1 SHC 75W-90 is recommended by ExxonMobil for use in applications requiring: API GL-4 ZF TE-ML 08 http://www.mobil.com/UK-English-LCW/heavyd...5w90.aspx# Can this oil be used on my puma both gear and transfer case as it has properties of GL4 and GL5? Cheers ! Regards, Diluk |
