![]() | Home > Wheels & Tyres > 255/85 advice |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2515 ![]() ![]() |
I run 265/75’s on my 16 inch sawtooth’s , the 255/85’s will be taller but narrower so you should be able to fit with no problem at all. Noting for balancing you may wish to look at beads rather than standard weights as the 255/85’s are generally only in an MT.
A minor adjustment of the stops to prevent rubbing on full steering lock may be required but that’s all. PS. If your sawtooth’s are factory they will be ET20 , it will be stamped on the inner side of the wheel. Last edited by Ianh on 7th Nov 2021 9:20pm. Edited 1 time in total |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Excellent tyre size !!
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
Since I first saw pics of them, I’ve fancied these, but so far they haven’t been available as All Terrain’s, just M/T and my useage just doesn’t justify that.
Anyone know if they’re available in A/T yet? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
255s really look the business. I have them on dual-finish et33 with no problem.
On Sawtooths they will be great as they have the same et20,6 as wolfs but are half an inch wider. ![]() Click image to enlarge Roaming around 🇳🇴🇨🇭 Last edited by Angus_Beef on 7th Nov 2021 9:42pm. Edited 1 time in total |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2683 ![]() ![]() ![]() |
My last 110 on Wolf wheels with a two inch lift
![]() And stuffed into the wheel arch ![]() Click image to enlarge |
![]() Click image to enlarge Now on these … ![]() Click image to enlarge ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
255/85 for me, I’ve ran them for a good 4 years now. On Boost rims but great tyre size.
I prefer them to 235’s. I have never lost traction off-road with them, mud, take it all. Just go easy in the wet like all MT’s. I run on MT’s all the time, lots on road but I only do around 6 - 8k a year. Dynabeads are good. Dynabeads and weights work too, if you have no weights or don’t want any. A bit more Dynabeads in weight maybe useful. See Blackwolfs posts on here regarding Dynabeads and application quantity. Mine has the standard recommended amount but you can go somewhat higher in weight. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1371 ![]() ![]() |
i have 255/85's on mine, i do have a 2 inch lift but they'd be fine on standard ride height
wdef34 Member Since: 26 Sep 2017 Location: ....................... Posts: 15 ![]() ![]() |
Hello, the only A/T 255/85 i am aware of is the toyo m55 (ultra hi quality commercial tyre), if you have a kidney to spare...
Thanks for that - but you’re not kidding about the cost!! $360 each!
I’ll keep hoping. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 123 ![]() ![]() ![]() |
Hi DeeEss! On 255 it looks really good ![]() Thank you for your info Grüss Lolo |
Simboii Member Since: 09 Jun 2021 Location: Carmarthen Posts: 85 ![]() ![]() ![]() |
Think the 255/85’s are the way forward, just look right with the height and not too wide!
On spacers?? |
Hi Lolo, no problem at MfK with 255/85R16 as long as they are on an approved 6.5 or 7 inch rim 👍🏼 Roaming around 🇳🇴🇨🇭 |
Thank you DeeEss
