![]() | Home > Td5 > transfer box |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Yes, they all run the same kind of t/box, LT230. even the new puma defenders use a 1.2
The discovery box is an LT230Q... Quiet(er) gears apparently. ![]() Td5 defenders are 1.4 |
Not sure that's correct - the TR90 went in for a new gearbox and I had the ratios done at the same time (£260ish extra) and they swapped the ratios out in my existing transfer box. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 263 ![]() ![]() |
sorry you are mistaken, if we do the ratio swap we chnage the gears in your unit, if you order a rebuilt unit then it's changed for another Dave Dave |
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 ![]() ![]() ![]() |
i will be keeping an eye on this thred as this is something i would like to do
buds Member Since: 30 Aug 2010 Location: isle of wight Posts: 15 ![]() |
can i just ask will the disco 2 box fit with out any mods as some have said it will
really not sure which way yo go here thanks |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
overdrive? then you have the best of both worlds
