![]() | Home > Td5 > Cruise control switches? |
If you want a nakatanenga product in England you need to speak to 4x4 overlander. They may not have the part on their site but a quick call will get you sorted or a pm to Leeds on here. They are site sponsors too
![]() My build thread http://www.defender2.net/forum/topic17615.html |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3468 ![]() ![]() |
Great thanks l will call them in the morning.
Adammac Member Since: 26 Oct 2021 Location: Limerick Posts: 2 ![]() ![]() ![]() |
To answer the original question, they do produce a cruise control switch AMR3599-G.
My setup: ![]() ![]() Click image to enlarge Made in 2010 as a quick trial, always on the list to make it nice. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
That looks like it is from a Range Rover so the design is slightly different design to a Td5 Defender switch and my OCD wouldn't be able to cope with that! I use the disco 2 steering wheel switches mounted on the column cowling and have no switch for the Cruise on/off. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
l fitted the Nakatanenga kit to my 2005 TD5 110 Defender.
The two black push buttons (set/resume) l installed in the centre console below the stereo. l didn't bother with an on/off switch for the cruise, it all seems to work fine and has now been on the Defender for two years. |
