![]() | Home > Maintenance & Modifications > Dingo II window/clamp mount CB aerial - any experience? |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Possible alternatives includes taking cable under top of door seal then down the back of the A pillar post cover.
Another alternative if you have a snorkel is to tywrap cable to outside of snorkel then going under bonnet and then through one of grommets in the bulkhead. Brendan |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
Thanks Brendan - had thought about the snorkel route - that would be reasonably neat.
To everyone else - anyone got experience of using the Dingo II? S |
I've never used one but, having looked at the details on 4x4cb.com, I'd say it's ok for road use but not green laning or similar. IMHO there would be a very real danger of breaking a window if the aerial or mount were to be clobbered by a tree.
On my old DI I fixed a length of black plastic conduit to the side of a Safari snorkel, up which were routed a CB aerial lead and power feeds for roof mounted lights. ![]() It worked really well in that everything was neat and tidy and it gave a bit of flexibility as things were added or changed. If you've already got a roof rack and a snorkel then that would seem to offer a neat and robust solution. Other than that, buy a decent gutter mount and run the cable through the door seal as already suggested. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
yes - I've been giving this some thought and I think you're right in that it would be likely to be hit by a tree and snap or worse still break a window - think I'll go for a cable up the outside of the snorkel and across to a rack mounted unit in the centre of the truck
Thanks for the advice |
