![]() | Home > Maintenance & Modifications > Fittings for chequerplate |
iforland Member Since: 27 Mar 2021 Location: redditch Posts: 17 ![]() ![]() ![]() |
mine had checkplate as fitted by Land Rover and they were all rivnuts, looks like they are stainless steel as they have no rust....
However, I still have serious Aluminium corrosion around the rivnuts, to the point where a couple of the fittings aren't secured anymore. |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 473 ![]() ![]() |
Thank you.
Would aluminium rivnuts be any good then as opposed to stainless? |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2683 ![]() ![]() ![]() |
My wing top are Mammoth, and yes the look and finish is very good.
Been on the 90 or nearly eleven and a half years now, only change a few years back was that I had then anodised black. I can’t remember if they come standard with the neoprene backing to act as a sandwich between the wing and the protector. If not you can buy it by the sheet off eBay, get the adhesive backed version. My riv nuts are stainless. Just let the paint have time to dry after drilling the hole before setting the riv nuts. I take mine off every couple of years to clean away any dirt that always find a way there. I also swapped the original stainless fittings for black versions. ![]() |
Excellent, thank you.
I have seen them with the rubber gaskets, and I was going to consider putting the self expanding foam tape all around the edge to finish off. I did this with the gap between the chequerplate on the sils and the body and it worked a treat, filled the 2mm-ish gap and looks spot on, result can be seen here https://www.defender2.net/forum/topic73542.html So for now it looks like the rivnut route will be best, easier for any future cleaning/resto etc. Cheers ![]() |
My originals also come with the black waterproof foam backing, which is good.
Agree that if LR had painted after drilling holes that there might be less corrosion...but you could say the same for the tub cappings, re-enforcing plates etc. none of which appear to have anything other than a primer coating on the underside!! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
Why not only glue? Fake screw heads if the checker plate is predrilled for rivets. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Hi,
Not sure about glueing it on, would make a heck of a mess on the surface and not ideal for taking off to rufurb in the future? |
Agree that taking them off is more difficult if glued, but you will not end up with holes that need to cover up if you decide to remove permanently. You will have to repaint though.
If you go for screw, washer and nut combination, check that you can reach to get the washer and nut in. If drilling, ensure that you do not go through into whatever is beneath the wing, such as windscreen washer bottle. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
I have just fitted some Mammouth ones - came with c/sunk hex head bolts, stainless washers and nylon nuts. Made a couple of gaskets out of 1mm neoprene. Rgds.
Chris |
Hi Chris,
Thank you. I have ordered a set of Mammoth ones, so I wil see what they come with and take it from there. Many thanks for the help. ![]() |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 787 ![]() |
Mammoth supply the neoprene gaskets separately but I think their chequerplate comes with countersunk bolts and fixings
Hi,
Yep; I ordered the gaskets too so hopefully it will arrive tomorrow and I can take it form there. Many thanks for the advice. Cheers |
If I were doing it from scratch, I'd use aluminium rivnuts so that they're compatible with the wing and then apply an appropriate barrier paste to the stainless bolts - Duralac or similar. Darren
