Home > Maintenance & Modifications > EML Help!
Stiff1
EML Help!
So yesterday as driving , after about 10min the EML came on, pulled over checked oil and water, all levels correct and clean and no unusual noises or change in drive. No other warning lights and temp gauge stayed in the middle.
Returned home and as I went became aware the heater matrix area was getting very hot, very. Turned the fan up fully until I got back.
Short drive today produced the exact same symptoms.
Ideas please.
Post #926168 18th Oct 2021 10:35am
Has it had a coolant change recently and if so was it bled properly ? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #926178 18th Oct 2021 11:42am
Stiff1
No, just levels checked.
Post #926183 18th Oct 2021 11:59am
Dinnu
Is it possible to read the ecu for any faults? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926184 18th Oct 2021 12:08pm
Stiff1
Sadly not, have it booked into main dealer (£££) tomorrow to check.
Was wondering if the water pump would be a suspect but not sure the heat would get to the heater matrix so quickly?
Post #926188 18th Oct 2021 12:22pm
Dinnu
Get a cheap ELM327, wifi or bluetooth, and download an app on your phone to read codes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926190 18th Oct 2021 12:29pm
dorsetsmith
If your coolant pump problem engine temp will be in the red go to limp mod with dtc
Post #926192 18th Oct 2021 12:45pm
