![]() | Home > Maintenance & Modifications > EML Help! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Has it had a coolant change recently and if so was it bled properly ? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 604 ![]() ![]() ![]() |
No, just levels checked.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3648 ![]() ![]() ![]() |
Is it possible to read the ecu for any faults? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Sadly not, have it booked into main dealer (£££) tomorrow to check.
Was wondering if the water pump would be a suspect but not sure the heat would get to the heater matrix so quickly? |
Get a cheap ELM327, wifi or bluetooth, and download an app on your phone to read codes. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
If your coolant pump problem engine temp will be in the red go to limp mod with dtc |
