![]() | Home > Maintenance & Modifications > Puma Heated Seats |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 302 ![]() ![]() ![]() |
You should feel them especially on your butt ocks (as forest gump would say) and lower back.
Double check there isnt any inline fuses - have you checked the passenger side to see if that is getting warm? Pop the seat base up and double check all connections underneath also could be just a loose plug, let us know how you get on. |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
The puma seats don't give off anywhere near as much heat as others I've used..
SWMBOs evoque cooks your backside, the standard puma ones are more of a gentle warming to take the chill off... That said, if you're not feeling anything at all it points to an issue. Is it the same with both passenger and driver seats? ![]() |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1490 ![]() ![]() ![]() |
There's a common fault with puma heated seats, my driver side stopped working. Good place to start looking, and an excellent how to here:
https://www.defender2.net/forum/topic76500...eat+broken |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371 ![]() ![]() |
[quote="camelman"]The puma seats don't give off anywhere near as much heat as others I've used..
SWMBOs evoque cooks your backside, the standard puma ones are more of a gentle warming to take the chill offquote] Mine cook! It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Mine will roast chestnuts! Roaming around 🇳🇴🇨ðŸ‡
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2268 ![]() ![]() ![]() |
Same here have had both std XS and the premium and plenty warm enough...
J1990 Member Since: 24 Aug 2021 Location: South West Posts: 39 ![]() ![]() ![]() |
I used this as an excuse for a drive out this morning, turned on the passenger heated seats and there is heat being generated but it still seems to be really quite low amounts, though actually noticable so better than the drivers side.
This weekend I'll pull out the seats and check the thermostat/wiring as per the attached thread, hopefully it's something as simple as that. If this isn't the issue, any suggestions how I'd go about detecting where the problem was or is it simpler/smarter to just replace the heating elements and wiring given that it's over a decade old anyway? PS - Thanks for the input so far guys, it seems like the stock heating is capable of good heat, it's just a little hesitant to give me more than lukewarm. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8362 ![]() ![]() ![]() |
Mine get really hot, as good as ffrr and audi/vws Cheers
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924 ![]() ![]() ![]() |
I stuck our Puma’s seats into my Td5. They’re luke warm compared to my old Td5 seats. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Defender seats aren’t as hot as others which I like. I switch them on in the start of September and off in about Easter.
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 123 ![]() ![]() ![]() |
I can feel the heat, but nothing extraordinary, even if it has been replaced and are brand new. I would say I can compare the heat level to something between level 1 and level 2 out of 3 of any heated seat in VW/Skoda/Audi. What puzzeled me is that it seems to shut down after 5 -8 minutes or so. Normal?
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello All
Rather than start a New Post I thought i'd add to this one as it's general in nature... Q. Does anyone know if the under seat connectors (Heated Seats) are available? I have a broken yellow wire (assume +) and connected black (-) on one (male) connector (drivers side... so I have a wish to fix before winter ![]() The Connector needs replacing and has also partially melted, only slightly but you can just see (right hand plug) some deformation, possibly due to the broken wire. Part No's for a direct replacement for a male / female / combined connector, would be great or if not a recommended 'alternative' for an easy plug in and unplug connector... ![]() Click image to enlarge Thanks... SKIP https://www.defender2.net/forum/topic83242.html |
They don't look like the OE connectors for heated seats. Those are black like this:
![]() Click image to enlarge They're available from Mobile Centre amongst others: https://www.mobilecentre.co.uk/2-way-male-...mp;_page=1 https://www.mobilecentre.co.uk/2-way-femal...-ypc500360 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The are definitely not OE plugs, and probably neither are the seat heaters. You look like you have Waeco seat heaters. If so there is usually a switch which allows the user to increase or decrease the heat they put out.
Might be worth tracing the wiring to check for the variable heat switch/dial... Like this ![]() |
