Home > Wheels & Tyres > Rims: Nakatanenga Classic vs Wolf
Page 2 of 3 <123>
JOW240725
I fitted extended wheel studs for both the wolf style and ANR rims. Whilst apparently OK I wasn't happy with the nut only half on. James
Instagram @suffolk_rovers
Post #923363 29th Sep 2021 10:57am
geobloke
Good lord of Land Rovers I do very much like the Naka and Wolf rims... Thumbs Up Rolling Eyes
Post #923366 29th Sep 2021 11:16am
Same here.
Over tightening nuts can stretch bolts and strain threads apparently.
Post #923535 29th Sep 2021 9:44pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Not sure what your issue was, as the stud should fully engage with your standard LR steel wheel nut thread as you can see here…
As for the over tightening statement not sure what relevance that has to length of stud, but there’s a simple solution there don’t over tighten them 😉
Post #923569 30th Sep 2021 6:21am
JOW240725
The nuts didn't engage like that on mine. I'd be happy with that photo. I had 2 - 3 clear threads showing on the nut. James
Post #923579 30th Sep 2021 6:52am
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
The rule of thumb is that the length of usable thread should equal the diameter of the stud = 16mm on a LR
It doesn’t make any difference if the stud does not reach the end of the nut,
I see this quite often on commercial vehicles that I inspect/repair
Post #923591 30th Sep 2021 7:47am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Steel wheel nuts tend to vary in size/depth..... Whistle
Post #923592 30th Sep 2021 7:55am
SteveG
👍👍 Good to know
That’s weird, personally I’ve only seen that issue on series hubs, not had an issue with length of studs on 2x TD5’s, 1x TDCi and 2x RRC’s (above pic) hubs with the thicker Wolf rims - but that’s not much of an extensive list, but it probably covers most of the hubs used with this stud pattern on LR’s for the last 35 years.
I know you get different stud lengths aftermarket, even though they have the same part number, but I had assumed factory stud length would have been consistent. If that’s not the case, then it’s a bit of a lottery whether they will fit or not.
It would be useful, to have a minimum length of stud needed posted on here. Then folks can measure theirs and know for sure if they’ll fit without changing out studs prior to purchase.
Post #923594 30th Sep 2021 7:58am
Puma90
Spain 2011 Defender 90 Puma 2.4 SW Santorini Black
Hi all,
This is a picture of an original Heritage Edition Defender
I do not know if this Special Edition model was build with longer studs than the normal Defender when equipping the Wolf rims as standard, but it seems that the nuts & studs are OK.
Another question between Wolf & Nakas, does the turning circle gets worse with Nakas with 265 vs Wolf with 235? Or because of the Naka’s ET0 with 265 the turning circle is equal to the original wolf’s with 235?
Thanks a lot to all!!
Post #923639 30th Sep 2021 9:52am
Puma90
Hello,
In the end I have made a decision, maybe a little weird but it is in relation to the color of my car.
The car now is Santorini Black, I like this color but I love green Defenders and I have doubts whether to change the color of my car to Keswick Green. My doubts are if in case my Defender will lose value because it will not be the original color, but that's another story ...
If I decide to paint her in Keswick, I will go for a more classic look and opt for a genuine Wolf with 235 tire size.
If I keep her in Santorini Black, she will have a more aggressive touch and I think a 265 tire size would suit it better with the Naka’s Classic. For all that I have been able to read in this great forum, I believe that being ET0 wheels will not affect the car's turning circle by increasing the tire's size.
I attach a photo of how my car is actually, with a Dual Finish Wheels and tire size 235.
I promise photos of the final result!
Again, I would like to thank you for all the help you have given me both in this thread and in the entire forum itself.
All the best!
Post #923998 2nd Oct 2021 7:06am
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
Thanks to you for bringing such a friendly vibe to this place. 👍
Post #924001 2nd Oct 2021 7:19am
m33ufo
Wales
I have the Nakatanenga's with 265/75 KM3's. Love them.
Can I ask what pressures people are running with this tyre size? 110 DCPU
Mark
Post #924073 2nd Oct 2021 3:51pm
m33ufo
Wales
Finished in Santorini Black. Look awesome in the flesh but not the easiest colour to photograph.
Wrington Engineering nuts set them off.
Originall on factory Wolf's with Goodyear MTR's.
 110 DCPU
Mark
Post #924080 2nd Oct 2021 4:35pm
Puma90
Hello Mark,
Your Defender looks stunning!!!
Did you notice any worse in the turning circle when you swapped the Wolfs for the Nakas?
They look beautiful in black with the white car Thumbs Up
Post #924119 2nd Oct 2021 10:26pm
m33ufo
Wales
Thank you.
Literally fit them today. Initially i went for satin black but changed to Santorini. Really happy with them, although black doesn’t come across well in photos.
I’ll have to update you on how they drive once I have an opportunity to take her for a drive. 110 DCPU
Mark
Post #924122 2nd Oct 2021 10:41pm
Page 2 of 3 <123>
