Home > Maintenance & Modifications > Early windscreen hinges to the later "non hinged"
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
My Ninety has the original "proper" windscreen hinges, but they are heavily corroded. Can I just change these for the later "non hinged" type without any modifications? I assume I can also lose the inner securing bolts at the same time?
Thanks!
Post #922999 27th Sep 2021 12:03pm
rallysteve
Yes you can just swap them for the fixed type but be aware, you will need the metal plates and spacers for the inside which the three bolts fit through:
AYF500090
LR016689 &
LR016671
See here: https://www.lrworkshop.com/diagrams/land-r...reen_52775
Post #923003 27th Sep 2021 1:09pm
Dinnu
Get a good PZ4 bit (pozi drive not phillips) that you can fit in a good ratchet, to get the screws that go through the windscreen frame. Mine were damn hard to undo, but managed after a bit of persuasion.
You can still drill the head off if unscrewing fails. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923014 27th Sep 2021 2:32pm
Woody3
Thank you Steve and Dinnu, much appreciated!
Thumbs Up
Post #923021 27th Sep 2021 3:28pm
What's the pozi-drive bit for, Dinnu? I'm sure that when I did this on my old 90 it was just three M8 bolts on each side Confused Darren
Post #923027 27th Sep 2021 4:08pm
rallysteve
Old hinged setups used a large countersunk pan-head through the windscreen, rather than hex-heads 02' 110 TD5 Double Cab Rebuild Thread
Post #923030 27th Sep 2021 4:17pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
I've just rebuilt my 90 and it had folding hinges that i needed to remove for the re-paint. The job was made easier with the windscreen frame on the bench but still took a variety of persauding tools to eventually get the screws out. When i re-fitted them i used hex head bolts.
Post #923067 27th Sep 2021 6:35pm
Dinnu
Yes, as above. Mine are M10. The ones through the bulkhead are M8 hex screws. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923103 27th Sep 2021 9:32pm
