![]() | Home > Maintenance & Modifications > Early windscreen hinges to the later "non hinged" |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Yes you can just swap them for the fixed type but be aware, you will need the metal plates and spacers for the inside which the three bolts fit through:
AYF500090 LR016689 & LR016671 See here: https://www.lrworkshop.com/diagrams/land-r...reen_52775 Steve 02' 110 TD5 Double Cab Rebuild Thread |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
Get a good PZ4 bit (pozi drive not phillips) that you can fit in a good ratchet, to get the screws that go through the windscreen frame. Mine were damn hard to undo, but managed after a bit of persuasion.
You can still drill the head off if unscrewing fails. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 ![]() ![]() ![]() |
Thank you Steve and Dinnu, much appreciated!
What's the pozi-drive bit for, Dinnu? I'm sure that when I did this on my old 90 it was just three M8 bolts on each side ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Old hinged setups used a large countersunk pan-head through the windscreen, rather than hex-heads 02' 110 TD5 Double Cab Rebuild Thread
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 410 ![]() ![]() ![]() |
I've just rebuilt my 90 and it had folding hinges that i needed to remove for the re-paint. The job was made easier with the windscreen frame on the bench but still took a variety of persauding tools to eventually get the screws out. When i re-fitted them i used hex head bolts.
Yes, as above. Mine are M10. The ones through the bulkhead are M8 hex screws. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
