![]() | Home > Technical > A/C Removal |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
What model is your defender? If it’s a TDCI, the evaporator is an absolute nightmare to get to!
| Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4341
If you end up leaving anything in place, evaporator for example, seal any open ports/connections so the internals don’t get dirty and can then be used again by you or a future owner. 2007 110 TDCi Station Wagon XS
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
I believe the OP is talking about a Td5 and earlier below dash unit. It would indeed free up a lot of space if removed.
Most components have been mentioned, just an air dryer bolted to the left mudguard (or wing if you like) - unsure if it would be on opposite side on LHD vehicles. Will also have quite a large hole (around 2", or perhaps less) in the bulkhead where the refrigerant tubing pass through that needs to be plugged, and a smaller hole for the condensed water. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| seventhtiger Member Since: 15 Jun 2021 Location: Vancouver Posts: 18
TD5. Yes, correct Dinnu.
It seems pretty straight forward. I managed to find the install instructions so I’ll just reverse. The system seems to sit independent of any systems on the truck itself so other than the power tap that should be it. |
