Home > Technical > A/C Removal
seventhtiger
Canada
A/C Removal
Hi - I have an inoperable AC unit that came with my imported defender. I am going to remove it, since the space I'll gain and the hassle to replace parts is not worth my time.
Anything I need to be mindful of when taking things out/apart? As I can see it - apart from the unit in the cab, there is the condenser to remove, the cooling rad out front, the compressor...anything else?
And before you ask...it has been drained by the previous owner so there is no issue with the AC fluid etc.
I am not sure it's a factory unit or a Wabasco (?) but it's similar regardless.
TIA.
Post #922390 22nd Sep 2021 6:11pm
Co1
What model is your defender? If it’s a TDCI, the evaporator is an absolute nightmare to get to!
Post #922394 22nd Sep 2021 6:46pm
Bluest
If you end up leaving anything in place, evaporator for example, seal any open ports/connections so the internals don’t get dirty and can then be used again by you or a future owner. 2007 110 TDCi Station Wagon XS
Post #922397 22nd Sep 2021 6:49pm
Dinnu
I believe the OP is talking about a Td5 and earlier below dash unit. It would indeed free up a lot of space if removed.
Most components have been mentioned, just an air dryer bolted to the left mudguard (or wing if you like) - unsure if it would be on opposite side on LHD vehicles.
Will also have quite a large hole (around 2", or perhaps less) in the bulkhead where the refrigerant tubing pass through that needs to be plugged, and a smaller hole for the condensed water. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #922399 22nd Sep 2021 6:58pm
seventhtiger
Canada
TD5. Yes, correct Dinnu.
It seems pretty straight forward. I managed to find the install instructions so I’ll just reverse.
The system seems to sit independent of any systems on the truck itself so other than the power tap that should be it.
Post #922421 22nd Sep 2021 10:57pm
