![]() | Home > Td5 > Intermittent Starting Issue |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 1000 ![]() ![]() ![]() |
Suggest you…1 plug it in and see if there are any codes. 2 check for oil in the ECU plug
Good luck. 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
None and dry.
Boo! That sucks…. Have you checked the duck valve in the fuel filter head? 2020 range Rover Mk IV Autobiography PHEV
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3509 ![]() ![]() |
l had exactly the same issue with our TD5 90
After changing the injector seals, fuel filter housing, battery, FPR, MAF unit, injector harness, and no change The fault was the STARTER MOTOR It was working, but producing some sort of voltage spike or interference that was messing up the ECU and causing the intermittent starting issues. Last edited by lightning on 29th Nov 2021 10:16am. Edited 1 time in total |
Similar to the above statement. Fitted a Britpart starter motor and then began having horrendous starting problems as with yourself. Replaced the starter motor and bobs your uncle all A-OK once more.
Having said that how bad is the fuel pump? I had a noisy Bearmach pump in Miffy that over time got noisier and then the engine began to do the same as you describe. Turned out the pump was not making the required fuel pressure. I would try and pressure test the pump first. See whether that is behaving. If it is the pump only buy VDO… ![]() |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408 ![]() ![]() |
I’d start by changing the pump, if it’s noisy then it’s certainly on its way out and even if it doesn’t fix this issue then it will most likely stop you getting an issue with it further down the road. - not cheap but go for a genuine VDO one and not aftermarket
Does it crank over at a reasonable speed? I.e. a speed that it should start at? |
What is the voltage while Cranking? If the voltage is too low the ecu will stop working and you get no fuel injected.
As asked before how is your cranking speed. The grease in the reduction gears can get sticky. I could hardly turn it by hand. I changed it to normal bearing grease and it cranks a lot faster. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
