![]() | Home > Maintenance & Modifications > Rear Door lock - barrel too long? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
Do you have photos?
Something is odd or its not the original rear lock, my 2007 uses the ignition key for the rear door. HTH Keith |
CalumD23 Member Since: 30 Aug 2021 Location: Surrey Posts: 37 ![]() ![]() ![]() |
Thanks for the reply Keith. I think it’s not the original lock, as the lock is clearly too small for the hole on the outer of the door.
New tumbler in lock: ![]() Click image to enlarge New tumbler (top), old tumbler (bottom): ![]() Click image to enlarge |
There should be a plastic finisher or escutcheon on the outer panel.
If you replace the rear lock, I've not long done mine, used a Britpart one and the quality isn't great.... The small key certainly doesn't look right for your age of car. Good luck |
Thanks for the help. For anyone else with the same query, the shorter barrels are from older models (pre 2002 I think?) and therefore the previous owner had stitched me up. A new rear lock is £30 from bearmach and it takes the longer barrels so that’s the solution! Part number LR031336.
