Home > Technical > Cannot lock my car... |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 601 |
Normally the bracket gets bent when engine bay work has been done so the plunger doesn’t contact the bonnet properly, but as yours hasn’t been opened it shouldn’t be that.
14th Sep 2021 7:31pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Had the same problem a while ago, sought advice on here and it turned out to be the drivers door actuator.
Buy an OEM not the cheaper alternative - don't ask me how I know Just because you're offended doesn't mean you're right. |
14th Sep 2021 7:41pm |
i have also find if bonnet hinge bush fitted upside down shorten the life of the switch to
14th Sep 2021 8:26pm |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 295 |
Have you tried some lubricant or wd40 on the actuators as they maybe stuck, usually if the car is unlocked then tries to lock it will send a signal back saying one the actuators can't lock so the full car won't lock - sort of a open/closed relay circuit - all actuators will need to lock to complete the circuit.
14th Sep 2021 9:04pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
I will try wd40 first
If its the bonnet plunger or drivers door lock how can I tell? Can I unplug the bonnet one and will it still lock? So at least I can narrow it down... assuming wd40 does nor work. Thanks |
15th Sep 2021 7:39am |
Not sure on the plunger - but if you pop your door card off to get to the actuator - if its been sat especially in warm weather it could have dried/seized up. Hopefully be an easy fix.
Just check your door push button and lock mechanisms in the door are locking and grabbing the door striker also. |
15th Sep 2021 8:41am |
As a test, put a cable tie or similar around the bonnet plunger and see if it locks. If it does, you've found your culprit and have a temporary solution.
My money would be on the door mechanism though - the latch and various links to the actuator. Any resistance in the movement of these parts and the actuator won't complete its travel but instead bounce back open in the way that you've described. The grease used originally on these parts has a habit of hardening over time. Apply your lubricant or grease of choice and give it a go. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Sep 2021 8:56am |
Thanks all
I did try first pushing the bonnet plunger down as I locked car... no luck still unlocked I then sprayed wd40 in the locks, down the door pin etc... Still unlocked So door card off, used a small screwdriver to access inside the little rubber boot from acculator and sprayed wd40. Result.... it worked 💪 Thanks all |
15th Sep 2021 10:11am |
Boooooooooooooooom cant beat a bit of WD40
15th Sep 2021 10:31am |
