Home > Puma (Tdci) > Clutch or not to Clutch is that the noise?
PMU
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi,
I have a 2008 110 with the 2.4 puma engine which I have owned for about a year. every now an then when pulling away from a junction and more frequently when off road ( so under strain ) I have this strange rattle/stroke vibration which almost sounds like when you spring an old ruler on the table if that makes sense?.
Someone suggested it could be the spiggot bearing so therefore change the whole clutch etc. ?
The second question is if I do is it worth sticking to with genuine or an alternative?
TIA
Post #921366 13th Sep 2021 10:34pm
Ianh
Lof, Transit 4x4, and clutchfix clutch’s all have their fans on here ahead of the gen landrover offering. But while you are in there you need to have the output shaft checked for wear and replaced if needed. Greased versions from landrover or updated version from Ashcroft or more radical one piece solution from Lof are available.
Post #921367 13th Sep 2021 10:43pm
PMU
Thanks IanH
Post #921507 14th Sep 2021 9:24pm
Benrlelliott
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Aintree Green
Post #921607 15th Sep 2021 3:27pm
PMU
Thanks, more food for thought !
Post #921669 15th Sep 2021 11:06pm
