Home > Maintenance & Modifications > Transfer Box Swarf
Grenadier
Transfer Box Swarf
Evening all,
Just completed a full oils/lubes/filters service and whilst doing the transfer box noticed some swarf on the magnet. Very fine, not much, thin layer. Should I be worried? Anything I should do? Everything feels normal.
Have an HD clutch and Ashcroft Output shaft heading this way in the next few weeks.
Thoughts? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #921289 13th Sep 2021 5:07pm
Co1
How old is the oil?
Post #921313 13th Sep 2021 7:18pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Unlikely to be a problem if there are no other problems , it’s just the magnet doing it’s job.
If there were big lumps or the box was noisy or playing up , it might warrant further investigation. 2002 td5 90 county hardtop
Post #921314 13th Sep 2021 7:22pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Co1 wrote:
How old is the oil?
Beat me to it Col. Rgds.
Chris
Post #921329 13th Sep 2021 8:23pm
Grenadier
Sorry for late reply. 30k (miles) Monsieur Le Grenadier
Post #921415 14th Sep 2021 12:04pm
Ianh
Did you measure the amount of oil you drained ? Was it the correct amount that should have been in there ?
Post #921423 14th Sep 2021 12:36pm
Grenadier
No I didn’t. But I’ve not seen any evidence of leakage. I was on post-op sofa duties for six weeks and Def remained in same spot throughout. No drops under the vehicle at all. From any of the key reservoirs: diffs, engine, gearbox, transfer box. What’s more, transfer box was very clean externally. As was the prop. I assume that if the amount of dirty oil was very low, there would be evidence all over the propshaft, and around that area of the chassis? There’s none.
I had an Output shaft failure in 2018. Unfortunately I was abroad and was recovered to a main LR dealer so they refused to fit anything other than LR parts, wouldn’t let me upgrade to HD clutch and Ashcroft shaft replacement. So, maybe it is wear and tear from that….? Monsieur Le Grenadier
Post #921674 16th Sep 2021 7:39am
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
On my 3rd change now.
Each time comes out looking like this… *about 25k miles between changes.
I wouldn’t be to worried.
Post #922863 26th Sep 2021 3:52pm
Grenadier wrote:
... I had an Output shaft failure in 2018. Unfortunately I was abroad and was recovered to a main LR dealer so they refused to fit anything other than LR parts, wouldn’t let me upgrade to HD clutch and Ashcroft shaft replacement. So, maybe it is wear and tear from that….?
That is one thing you can rule out, since the adaptor shaft occupies the casing between the MT82 and the LT230 so any detritus from the joint can't get into either box.
Post #922867 26th Sep 2021 4:33pm
Grenadier
Thanks all. Yannis, mine was a lot, lot less than that. A really fine layer of very fine shavings. Almost like asbestos or hair. Thumbs Up And thanks for the info on the shaft Blackwolf. Can rest easy. Monsieur Le Grenadier
Post #923142 28th Sep 2021 8:08am
Sadly if you have had one shaft failure already, you shouldn't assume that it will not happen again. Big Cry
Evidence from owners, especially from the survey carried out on this forum, suggests that vehicles on which the shafts fail suffer recurring failures with standard parts. If you are lucky enough to have one where the shaft doesn't fail rapidly, it seems that they can last a very long time.
The evidence appears to support the suggestion that there is an underlying alignment or tolerance problem which a vehicle either has, or does not have. If you happen to own a vehicle prone to failure, I would strongly suggest that an Ashcroft or LOF coupling is considered. At the very least, the standard one should be lubricated very generously on assembly.
The jury is out on which part introduces the alignment or tolerance error, but my money is on the adaptor shaft housing (which joins the MT82 to the LT230).
Post #923159 28th Sep 2021 9:40am
Grenadier
Too true Blackwolf. Too true.
The only thing that I assume/presume when it comes to Defenders is:
a. I will love mine forever,
b. The next time it frustrates me is only just around the corner. Whistle
But specifically with regard to the Output Shaft, that’s exactly why I’ve bought an Ashcroft replacement and will get it fitted with a HD clutch fix clutch as soon as they arrive here from the UK. My last failure was in Spain and only a LR dealer was available to fix it. As such, they only allowed OE parts, despite my offering to buy and supply updated parts. I’ll rest more easily, but never complacently, when the replacement has been undertaken. Thumbs Up Monsieur Le Grenadier
Post #923164 28th Sep 2021 10:14am
