![]() | Home > Modifications & Maintenance (L663) > Fold down table. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
Well I have the fasteners, just need a table and a Defender to fit them to
![]() ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
PetroK Member Since: 07 Sep 2021 Location: NJ Posts: 4 ![]() ![]() |
Can you please advise what is diameter and lengths of this locks? There is no length mentioned in description and diameter seems to be 10mm, but Defender door screws seems to be M6, so this is a bit confusing. |
Those are the ones that I bought also, the thread is M6 and the length of the threaded bar is 50mm, the 22mm is the diameter of the black button part
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks for clarifying. And to install those caps into table itself, I need to drill 22mm holes in table surface?
Yes that's correct
Sorry half asleep when I wrote that, the 22mm refers to the diameter of the button, the hole size required was around 17mm
Thanks for clarification
Kingfisher24 Member Since: 28 Jul 2021 Location: New Forest Posts: 49 ![]() ![]() |
Thank you all for the modifications.
cyberhusky Member Since: 09 Feb 2021 Location: Luxembourg Posts: 280 ![]() ![]() |
Found on Aliexpress…
https://www.aliexpress.com/item/1005002702...2e0eL1oJyS ![]() Click image to enlarge 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history) Last edited by cyberhusky on 10th Oct 2021 8:01pm. Edited 1 time in total |
That's slightly different to the ones on Amazon and it's more than twice the price I paid when you include the £28.48 shipping!
![]() Click image to enlarge ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Ace7711 Member Since: 30 Sep 2021 Location: Hamburg Posts: 110 ![]() ![]() |
Here is mine.
Table bought on Amazon as well as the quick release hook snaps. The mounting kit I bought from Simon at Powerful UK. Makes installing just so easy. Works like a charm. Now I need to cover the screws to have a flat survace ![]() Click image to enlarge ![]() Click image to enlarge 110 D250 SE Tasman Blue, white roof, black pack, advanced towing pack, rear diff locker, driver assist |
