![]() | Home > Td5 > Engine rebuild - WHO SHOULD I TRUST |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
Turners
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1893 ![]() ![]() |
Turners for me too. Did my 300Tdi about a year and a half ago - delighted with it, and the peace of mind it brings to know that it was a reputable company behind the work. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
Turners.
Windsor Defender Member Since: 30 Aug 2021 Location: Windsor Posts: 3 ![]() ![]() ![]() |
Yup Turners is a strong company, had a 300 Tdi done by them but never really got to drive it as it was stolen after the 500 mile break in! Inside job ?
Donald how much was your rebuild approximately and what was included? Did you fit new injectors/pistons etc? |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1785 ![]() ![]() ![]() |
The first Turners rebuild in mine (under a previous owner) threw a rod after ~2000 miles and was replaced under warranty.
The second Turners rebuild (that was in the car when I bought it) threw it's timing chain out the window after ~20000 miles, but due to time wasn't covered under warranty. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
I wouldnt rebuild it. Id try and find a looked after second hand one.
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
if you rebuild it, I'd ask for all the journals and bore diameters to be measured properly i.e blueprinted as a report for the engine on delivery.
I asked for this and never got it although it was agreed and the engine is consuming oil which suggests the oil is passing the rings. My next job is to measure the bores for size and see if its in spec with the +10 oversize pistons. I don't think they will be. That being said you can do it yourself by sending the block out with a signed contract of your requirements and if its not they can argue the toss in a small claims court. I wish i had done this. |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
Turner's built an engine for me a few years ago (2.25 petrol). Yes there was a minor issue (crank seal nipped and leaking) - but the aftersales was phenomenal.
They paid to have a local specialist remove the engine, sent it to them, fixed and refitted complete with a new clutch. Couldn't believe it - I didn't pay a penny. I could have done it myself but I had just given up my workshop where I built the truck and after explaining this they sorted everything. Sometimes its not just the product to consider but also the aftersales. Can't guarantee anyone else would get this from them again - its definitely outside their warranty guarantee, might have just caught them on a good day. |
Thanks for the guidance , all helpful.
