Home > Td5 > Engine rebuild - WHO SHOULD I TRUST
Windsor Defender
England 2003 Defender 90 Td5 HT Baltic Blue
Td5 (2003 , SWB needs a rebuild. Has anyone had good service and good engine rebuild from companies near Heathrow/ Maidenhead?
Only one that springs to mind is Turners engineering.
Post #919355 31st Aug 2021 5:03pm
htb2
Turners
Post #919376 31st Aug 2021 7:08pm
donmacn
Turners for me too. Did my 300Tdi about a year and a half ago - delighted with it, and the peace of mind it brings to know that it was a reputable company behind the work. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #919378 31st Aug 2021 7:20pm
landy andy
Turners.
Post #919424 31st Aug 2021 9:09pm
Windsor Defender
Yup Turners is a strong company, had a 300 Tdi done by them but never really got to drive it as it was stolen after the 500 mile break in! Inside job ?
Donald how much was your rebuild approximately and what was included?
Did you fit new injectors/pistons etc?
Post #919425 31st Aug 2021 9:09pm
miker
The first Turners rebuild in mine (under a previous owner) threw a rod after ~2000 miles and was replaced under warranty.
The second Turners rebuild (that was in the car when I bought it) threw it's timing chain out the window after ~20000 miles, but due to time wasn't covered under warranty.
Post #919444 31st Aug 2021 10:45pm
bankz5152
I wouldnt rebuild it. Id try and find a looked after second hand one. Instagram @defender_ventures
Empire Tuning - Agent
Post #919529 1st Sep 2021 4:20pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
if you rebuild it, I'd ask for all the journals and bore diameters to be measured properly i.e blueprinted as a report for the engine on delivery.
I asked for this and never got it although it was agreed and the engine is consuming oil which suggests the oil is passing the rings.
My next job is to measure the bores for size and see if its in spec with the +10 oversize pistons. I don't think they will be.
That being said you can do it yourself by sending the block out with a signed contract of your requirements and if its not they can argue the toss in a small claims court. I wish i had done this.
Post #919537 1st Sep 2021 4:40pm
Gasket
Turner's built an engine for me a few years ago (2.25 petrol). Yes there was a minor issue (crank seal nipped and leaking) - but the aftersales was phenomenal.
They paid to have a local specialist remove the engine, sent it to them, fixed and refitted complete with a new clutch. Couldn't believe it - I didn't pay a penny.
I could have done it myself but I had just given up my workshop where I built the truck and after explaining this they sorted everything.
Sometimes its not just the product to consider but also the aftersales. Can't guarantee anyone else would get this from them again - its definitely outside their warranty guarantee, might have just caught them on a good day.
Post #919546 1st Sep 2021 5:23pm
Windsor Defender
Thanks for the guidance , all helpful.
Post #919595 1st Sep 2021 9:01pm
