Home > Td5 > Td5 Cruise Control Inop |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
Hi Bim,
TBH I havent had chance to revisit the cruise control issue, but hope to in the coming weeks, the system is back to standard, rewired and using the discovery set/resume switches. also tried another ECU just to rule that out. I'll keep you updated. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
13th Aug 2021 12:29pm |
Bim Member Since: 09 Jun 2018 Location: Cambs Posts: 28 |
I have the same problem not enough hours in the day
Bim |
14th Aug 2021 7:25pm |
Well on Saturday I had some spare time to take a proper look and my sister turned up in her 90 so I quickly plugged the nanocom to see the state of the switches on hers. I noticed on mine ‘brake switch 2’ was on which made sense due to the wiring of the cruise control, but my clutch switch showed on when not pressed but off when pressed, this worked opposite to my sisters
So looking at the wiring diagrams and checking the switches confirmed mine was NO and my sisters NC, so it turns out my original clutch switch was faulty but going by the listing for the clutch switch it isn’t right for a defender td5 but would be correct for a Puma and a Disco 2! New correct one ordered and fitted, Speedo healer and 5 pin relay wired in to use with and without overdrive, and guess what? Everything works as it should! So moral of the story is, Don’t trust vehicle fitment listings on suppliers website as they aren’t always right! Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
24th Aug 2021 11:11pm |
I have 2005 xs also so will check mine could be the parts bin had started to change for the new puma
26th Aug 2021 8:22pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1329 |
when mine did this it was a broken wire in the rear screen meaning the 3rd brake light didn't work.
27th Aug 2021 12:19pm |
Thats a good call lightening that would catch most out me included
8th Oct 2021 8:36pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2225 |
l didn't read his posts properly
He's beaten me to it in his reply above!! But l had exactly the same issue with mine after inadvertently fitting a Puma clutch switch last year. l've got the Nakatanenga cruise kit No overdrive fitted. |
8th Oct 2021 10:59pm |
Hi All,
Yes all up and running fine, was a puma clutch switch fitted, the issue is most Land Rover retailers list the clutch switch for Td5 and puma, but this is not the case. Td5 requires the red switch and Puma is the white one. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
8th Oct 2021 11:02pm |
