Home > Td5 > Td5 Cruise Control Inop
Page 2 of 2 <12
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Hi Bim,
TBH I havent had chance to revisit the cruise control issue, but hope to in the coming weeks, the system is back to standard, rewired and using the discovery set/resume switches. also tried another ECU just to rule that out.
I'll keep you updated.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #916716 13th Aug 2021 12:29pm
Bim
United Kingdom 2005 Defender 110 2.5 TD XS CSW Tonga Green
I have the same problem not enough hours in the day
Bim
Post #916990 14th Aug 2021 7:25pm
derbywill
Well on Saturday I had some spare time to take a proper look and my sister turned up in her 90 so I quickly plugged the nanocom to see the state of the switches on hers. I noticed on mine ‘brake switch 2’ was on which made sense due to the wiring of the cruise control, but my clutch switch showed on when not pressed but off when pressed, this worked opposite to my sisters
So looking at the wiring diagrams and checking the switches confirmed mine was NO and my sisters NC, so it turns out my original clutch switch was faulty but going by the listing for the clutch switch it isn’t right for a defender td5 but would be correct for a Puma and a Disco 2!
New correct one ordered and fitted, Speedo healer and 5 pin relay wired in to use with and without overdrive, and guess what? Everything works as it should!
So moral of the story is, Don’t trust vehicle fitment listings on suppliers website as they aren’t always right!
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #918610 24th Aug 2021 11:11pm
Bim
I have 2005 xs also so will check mine could be the parts bin had started to change for the new puma
Post #918831 26th Aug 2021 8:22pm
AJC
when mine did this it was a broken wire in the rear screen meaning the 3rd brake light didn't work.
Post #918869 27th Aug 2021 12:19pm
lightning
He's not posted since, l hope he got it working.
One thing to be aware of is, the Puma clutch switch looks the same as a TD5 one, but it works the opposite way round, as in pressing the clutch opens the switch rather than closes it.
l fitted a new clutch pedal box and it was a Puma one, then the cruise didn't work, the only thing it could be was the switch, which is how l found out.
Post #924997 8th Oct 2021 3:08pm
Bim
Thats a good call lightening that would catch most out me included
Post #925035 8th Oct 2021 8:36pm
lightning
l didn't read his posts properly
He's beaten me to it in his reply above!!
But l had exactly the same issue with mine after inadvertently fitting a Puma clutch switch last year.
l've got the Nakatanenga cruise kit
No overdrive fitted.
Post #925044 8th Oct 2021 10:59pm
derbywill
Hi All,
Yes all up and running fine, was a puma clutch switch fitted, the issue is most Land Rover retailers list the clutch switch for Td5 and puma, but this is not the case.
Td5 requires the red switch and Puma is the white one.
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #925045 8th Oct 2021 11:02pm
Page 2 of 2 <12
