Home > Maintenance & Modifications > Perei LED light question
Page 2 of 3 <123>
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Or the clear version, also having the same issues with the plinths but the Le Perei LEDs are fine.
Post #917614 18th Aug 2021 9:28pm
NickMSM
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Interesting regarding the plinths. I guess I'll buy a few more as back up but a bit irritating if they don't fare too well. My 90 is Stornoway, thinking red brake/tail light and the bottom two clear.
Post #917620 18th Aug 2021 10:02pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
https://www.optimill-uk.com/slim-rear-light-plinths.html
Optimill sell plinths - £180 for the rear end.
Def90 - that is a lovely looking truck 2011 CSW XS 90
Post #917672 19th Aug 2021 10:05am
You could buy several lifetimes supply of plastic ones for that! Darren
Post #917686 19th Aug 2021 10:38am
Mo Murphy
Reassuringly expensive Shocked
50 Shades of Pennine Grey
Post #917692 19th Aug 2021 10:48am
SJM2018
Almost justifies buying a hobby engineering lathe Laughing 2011 CSW XS 90
Post #917708 19th Aug 2021 11:54am
Machined aluminium and stainless screws - there's a recipe for disaster if ever there was one!
Post #917716 19th Aug 2021 12:37pm
NickMSM
LandRoverAnorak wrote:
The standard connectors are Econseal. For some reason on the SVX models, they used lamps with Superseal connectors and then had to introduce a short adapter loom. Anyway, buying Perei LED lamps with bare wires and then fitting Econoseal connectors is very easy to do if you have a decent terminal crimp tool. Otherwise, if you can buy them with connectors fitted then that would be easier.
I've fitted their stop/tail lamps to mine and will probably do the indicators too, at some point:
https://www.defender2.net/forum/post816358.html#816358
Do you have a link to those Econseals please? Dun-Bri sell a few but I am unsure which ones I need.
Post #922244 21st Sep 2021 5:44pm
Do you mean the plugs? If so, they came from eBay like this:
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
They're obviously three way ones for stop/tail lamps but a similar search for '2 way econoseal male' will bring up ones suitable for all other lamps. Darren
Post #922280 21st Sep 2021 9:59pm
NickMSM
That's them, thanks Very Happy Lights/plugs ordered.
Post #922358 22nd Sep 2021 2:29pm
Linds Hanson
Design and Development produce alloy slimline plinths which not only look much better than the clunky big plastic offerings but last forever too
Post #922368 22nd Sep 2021 3:28pm
NickMSM
What screws are people using to mount lights to the plinths? The torx head ones I have are slightly too long so it's pushing the plinth out a little from the tub. Also found the Perei lights don't fit very well in the dun-bri plinths compared to the genuine plinths in case anyone is doing the same upgrade.
Post #924196 3rd Oct 2021 10:47am
From memory, I've used 3.5mm x 15mm stainless posi screws.
All of my Perei lights have fitted various aftermarket plinths without issue. On the front I have the Bolt on Bits reducer plinths and on the rear, the sort that come with a couple of bolts that need to be removed. Darren
Post #924208 3rd Oct 2021 12:10pm
glpinxit
I used the same full-depth Dun Bri plinths front and rear. The light fittings are a little tight in them and, with hindsight, the answer might be to lightly run round the inside of the plinth lip with the Dremel drum sanding tool. On the front, I profiled the plinths to scribe them in around the edge profile of the front light panels. I think that the photo shows this- I tried the 'stand off' plinths but thought they looked like an awful bodge.
I've used stainless screws (security torx) as they all go into plastic blocks. For those who've observed their plinths stand off the body work- I used the dremmel sander to 'relieve' the flat base of the plinth (and its skirt) where it encountered rivets and the plastic blocks that the fixing screws go into which were causing the stand-off issue.
 Cheers, Guy.
Post #924311 4th Oct 2021 8:02am
Thanks Rolling Eyes Darren
Post #924313 4th Oct 2021 8:09am
Page 2 of 3 <123>
