![]() | Home > Puma (Tdci) > Puma Nato socket |
| BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403
Looks good. I've always put my 7 pin socket in that hole so it is out of the way and the wiring harness doesn't get minced on unsurfaced roads. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Looks good, Vitesse. How have you done the wiring? Did you buy a bare socket and connect directly to it or one with a tail and have some sort of junction box? How did you tee off the existing wiring? Darren
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 409
Thanks. In response to LandRoverAnorak, I bought a new (old stock) socket with cables already fitted. I then extended and connected (soldered) into the main Puma Harness for all relevant pickup for the lights. I also created some additional connections and sub loom for the convoy lamp ( used for the number plate light) and also permanent 12volts as the penman does have a 12volt power outlet on board. Basically so i can run the fridge when on the move to the camp site etc...
Click image to enlarge 2015 90 XS Santorini Black |
Excellent. Looks very smart. Darren
| All times are GMT |
