Home > Td5 > Poorly TD5 |
iforland Member Since: 27 Mar 2021 Location: redditch Posts: 17 |
Hi, try looking at this site to see if it helps:
https://www.lrworkshop.com/wiring-looms/de...om-td5-rhd From the site above it could be the rear heated window or washer.... |
31st Jul 2021 5:33pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2552 |
It’s a header, rather than a connector per se, so it only serves to join common wires together in a circuit. It looks like it was black as were the wires leading into it so it would most likely be an earth header.
31st Jul 2021 6:03pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Looked again on a larger screen and concur that it is the black header
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
31st Jul 2021 7:29pm |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 305 |
Might actually be the cause as I can see some ugly green corrosion that might have caused some high resistance, then melting....I think this has been reported on this board in the past.
Patrick |
31st Jul 2021 7:44pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 576 |
I have seen ad repaired (removed) quite o lot of these header, because of poor contact, corosion a finally some burn. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
1st Aug 2021 7:17am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 898 |
If you want, PM me with an email address and I’ll send you a pdf electrical manual for the 99 Td5
Good luck 🤞🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
1st Aug 2021 8:27pm |
A.Rubio Member Since: 04 Mar 2017 Location: Rocafort -Valencia Posts: 27 |
It is one of the diseases of Td5, the only solution is to eliminate these connectors or join them with cables and wrap them in heat shrinkable tube. The problem comes from the connectors, especially the ground one, the contacts get hot and come out on fire. It happened to me in Tunisia but I managed to get home and eliminate the connectors, all the connectors.
3rd Aug 2021 4:11pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Are they all the same polarity? i.e can they all be joined together as one or does the header contain multiple joints that need to be kept separated? Assuming all the wires are earth, I would check all earthing points in case one went bad and the current got diverted to the header, overloading it. |
5th Aug 2021 11:30pm |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 249 |
Can confirm that the connector is actually blue and not black and not all the cables going into it are black, I've got black, brown/blue, light green and a couple I haven't tracked down to some sheathing yet .... Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
16th Aug 2021 8:22pm |
And its this one
https://www.lrworkshop.com/connectors/defender-1999/C0287 i.e. Connector C0287 Got some 8 way "go away" earthing blocks need to find some smaller ones A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
16th Aug 2021 9:21pm |
In RAVE in electrical part, there is description of these headers, together with schematics.
I hade just replaced the header blocks with proper made soldered joints, covered in heatshrink tubes. No more problems. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
17th Aug 2021 5:45am |
Yup thats the plan. Started off thinking about chunkier connector blocks but going down the solder route
17th Aug 2021 9:01am |
Unfortunately they're not all earth wires, you've got 4 groups of wires Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
17th Aug 2021 9:02am |
