Home > Td5 > Poorly TD5
alexatnd
Poorly TD5
Think I've got a poorly 1999 10P TD5
Parked her up sat night everything was fine, went to move her Sunday lunchtime and strong smell of electrical burning. Took the batery out fairly damn fast. Initial symptom was a bubbling of the plastic fuse box cover . Had a furtle under the dashboard and found some charred plastic.
Removed the dashboard to find this. Can anyone point me in the direction of what that particular connector might have been servicing. ..Think it was blue to start with .. possibly black
Realise this is the effect and not the cause
Any help appreciated
Rgds
Alex
 Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #914906 31st Jul 2021 4:10pm
iforland
United Kingdom 1986 Defender 90 200 Tdi HT Arles Blue
Hi, try looking at this site to see if it helps:
https://www.lrworkshop.com/wiring-looms/de...om-td5-rhd
From the site above it could be the rear heated window or washer....
Post #914920 31st Jul 2021 5:33pm
Retroanaconda
It’s a header, rather than a connector per se, so it only serves to join common wires together in a circuit. It looks like it was black as were the wires leading into it so it would most likely be an earth header.
Post #914928 31st Jul 2021 6:03pm
rallysteve
Looked again on a larger screen and concur that it is the black header
Post #914941 31st Jul 2021 7:29pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Might actually be the cause as I can see some ugly green corrosion that might have caused some high resistance, then melting....I think this has been reported on this board in the past.
Patrick
Post #914944 31st Jul 2021 7:44pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I have seen ad repaired (removed) quite o lot of these header, because of poor contact, corosion a finally some burn. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #914971 1st Aug 2021 7:17am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If you want, PM me with an email address and I’ll send you a pdf electrical manual for the 99 Td5
Good luck 🤞🏻 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #915056 1st Aug 2021 8:27pm
A.Rubio
Spain
It is one of the diseases of Td5, the only solution is to eliminate these connectors or join them with cables and wrap them in heat shrinkable tube. The problem comes from the connectors, especially the ground one, the contacts get hot and come out on fire. It happened to me in Tunisia but I managed to get home and eliminate the connectors, all the connectors.
Post #915325 3rd Aug 2021 4:11pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Are they all the same polarity? i.e can they all be joined together as one or does the header contain multiple joints that need to be kept separated?
Assuming all the wires are earth, I would check all earthing points in case one went bad and the current got diverted to the header, overloading it.
Post #915713 5th Aug 2021 11:30pm
alexatnd
Can confirm that the connector is actually blue and not black and not all the cables going into it are black, I've got black, brown/blue, light green and a couple I haven't tracked down to some sheathing yet .... Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #917309 16th Aug 2021 8:22pm
alexatnd
And its this one
https://www.lrworkshop.com/connectors/defender-1999/C0287
i.e. Connector C0287
Got some 8 way "go away" earthing blocks need to find some smaller ones
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #917328 16th Aug 2021 9:21pm
MadTom
In RAVE in electrical part, there is description of these headers, together with schematics.
I hade just replaced the header blocks with proper made soldered joints, covered in heatshrink tubes. No more problems. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #917344 17th Aug 2021 5:45am
alexatnd
Yup thats the plan. Started off thinking about chunkier connector blocks but going down the solder route
Post #917361 17th Aug 2021 9:01am
alexatnd
Unfortunately they're not all earth wires, you've got 4 groups of wires Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #917362 17th Aug 2021 9:02am
