Home > Puma (Tdci) > Windscreen Frame -- material
nikojo
What is the windscreen frame made of??????
Doesn't seem to take a magnet but it seems harder than aluminum.
The front hinges also don't take a magnet.........are they aluminum???
Post #91321 26th Sep 2011 4:22am
dgardel
Italy
Yes and yes Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #91327 26th Sep 2011 7:42am
Zagato
The frame seems to be made of aluminium but with a high metal content (if you know what I mean!) as it does rust and is harder as you say for ally!
Post #91330 26th Sep 2011 7:47am
leeds
dgardel wrote:
Yes and yes
Actually the 100 % correct answer would be No and No
Aluminium is a metallic element whereas these items will be made from aluminium alloy of which there are hundreds of different ones.
Pure aluminium is extremely expensensive and very soft! We used to cut the end of a 3mm pure aluminium bar with a steel razor blade. Less then 5 gm cost over a £100 errr a few years ago.
Ok pedantic hat away now Rolling with laughter
I think the 'hinge blocks' are cast alloy. How is the ali frame made? My guess is that it would be cast. Does anyone actually know the answer?
Brendan
Post #91339 26th Sep 2011 9:04am
pom
i would get they are pressed/stamped like the panels
Pom
Post #91340 26th Sep 2011 9:08am
ZeDefender
I only know it's alloy 'cos I drilled through it to fit the snorkel Very Happy
Post #91677 27th Sep 2011 9:07pm
Happyoldgit
Cast alloy of some description IMHO. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #91687 27th Sep 2011 9:46pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
This is how it looks naked:
 Janusz
www.yahodeville.com
Post #91688 27th Sep 2011 9:49pm
Martin
Site Admin
If you look at it "raw" - i.e. without the trims on - it's clear that it's a casting.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #91689 27th Sep 2011 10:05pm
leeds
Having been in a 90 which had a 'gentle roll' the top of the windscreen frame just snapped which is typical of castings. Pressed/folded aluminium is more likely to show signs of stretching or bending before fracture.
I guessed that the windscreen frame was made by a casting process which other people seem to agree with.
Brendan
Post #91699 27th Sep 2011 10:34pm
Happyoldgit
Yep, definitely cast for sure, it's pretty soft and easy to drill. Steve.
Post #91733 28th Sep 2011 10:04am
Grockle
it'll be cast iron then Wink 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #91741 28th Sep 2011 10:57am
I thought it was made from playdough Whistle
Post #91743 28th Sep 2011 11:16am
