![]() | Home > Puma (Tdci) > Windscreen Frame -- material |
nikojo Member Since: 06 Aug 2011 Location: Madrid Posts: 75 ![]() |
What is the windscreen frame made of??????
Doesn't seem to take a magnet but it seems harder than aluminum. The front hinges also don't take a magnet.........are they aluminum??? |
Yes and yes Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Actually the 100 % correct answer would be No and No Aluminium is a metallic element whereas these items will be made from aluminium alloy of which there are hundreds of different ones. Pure aluminium is extremely expensensive and very soft! We used to cut the end of a 3mm pure aluminium bar with a steel razor blade. Less then 5 gm cost over a £100 errr a few years ago. Ok pedantic hat away now ![]() I think the 'hinge blocks' are cast alloy. How is the ali frame made? My guess is that it would be cast. Does anyone actually know the answer? Brendan |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
i would get they are pressed/stamped like the panels
Pom |
I only know it's alloy 'cos I drilled through it to fit the snorkel
Cast alloy of some description IMHO. Steve.
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
This is how it looks naked:
![]() Click image to enlarge Janusz www.yahodeville.com |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6696 ![]() ![]() ![]() |
If you look at it "raw" - i.e. without the trims on - it's clear that it's a casting.
Having been in a 90 which had a 'gentle roll' the top of the windscreen frame just snapped which is typical of castings. Pressed/folded aluminium is more likely to show signs of stretching or bending before fracture.
I guessed that the windscreen frame was made by a casting process which other people seem to agree with. Brendan |
Yep, definitely cast for sure, it's pretty soft and easy to drill. Steve.
it'll be cast iron then
![]() 1968 1/32 scale Britains 109 Pick up. |
I thought it was made from playdough
