![]() | Home > Technical > Wet black “stuff” in exhaust. |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1490 ![]() ![]() ![]() |
The average chemical formula for common diesel fuel is C12H23, ranging from approx. C10H20 to C15H28.
Water H2O and soot C are just 2 of the waste products of the combustion process, when combined with oxygen O from air. Would seem normal to me. https://en.m.wikipedia.org/wiki/Diesel_exhaust It might be a good idea to regularly check the engine coolant level, just in case any is finding it's way into the exhaust. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
If it’s running ok, and levels remain ok. Then I wouldn’t worry.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
A UK model 2.2 shouldn't have a sooty exhaust, due to the DPF.
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
In a typical UK climate, on average for every gallon of fuel you burn you emit a gallon of water. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 ![]() ![]() ![]() |
Thanks for the replies. It seems I’m being a hypochondriac. Having only had my defender a short time and never being able to look up a car exhaust before as they are now all hidden and pointed to the ground, I was a little shocked especially initially thinking it was oil.
I shall monitor levels, which I’m sure will be fine, then sleep easy tonight. |
