Home > Tdi > 300 tdi faults
spudfan
Ireland
300 tdi faults
Got a phone call from my daughter regarding her 300 tdi.
Temperature gauge not working, fuel gauge not working, indicators not working, rear wiper not working.
Windscreen wipers work, cigar lighter works, front lights work, hazard lights work, heating system works.
Any ideas 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #915837 6th Aug 2021 8:32pm
donmacn
I think that could be as simple as fuse #3 - 15A. It covers most of those things that are gone, and none of the things that are still going.
Above the transmission tunnel, upper row, third from the left.
Worth a try anyway. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #915841 6th Aug 2021 8:49pm
spudfan
Ireland
Thank you. I have forwarded on your suggestion to my daughter. Everything was working when she parked up and did not work when she restarted. So a fuse would fit the bill..hopefully. 1982 88" 2.25 diesel
Post #915844 6th Aug 2021 8:59pm
spudfan
Ireland
Worth a try anyway.
Bang on the button, all sorted now! Thumbs Up 1982 88" 2.25 diesel
Post #915867 6th Aug 2021 11:05pm
Mo Murphy
Now just need to find out why the fuse blew.
50 Shades of Pennine Grey
Post #916002 8th Aug 2021 9:16am
spudfan
Ireland
My thoughts exactly but according to my daughter everything is fine so far. The only time I had bother with fuses blowing on the Puma was when I borrowed a trailer. When I plugged it into the Puma it blew one of the fuses so the trailer lighting had a fault. My daughter does have a horsebox but up to now has had now bother when towing. Anyway if it goes again I told her to have it checked out. 1982 88" 2.25 diesel
Post #916034 8th Aug 2021 12:16pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Trailer socket is a good call. I had the indicator switch dropping apart inside and causing a short. If she has problems with indicators staying on it will need taking down and rebuilding. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #916059 8th Aug 2021 2:34pm
