![]() | Home > Tdi > 300 tdi faults |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Got a phone call from my daughter regarding her 300 tdi.
Temperature gauge not working, fuel gauge not working, indicators not working, rear wiper not working. Windscreen wipers work, cigar lighter works, front lights work, hazard lights work, heating system works. Any ideas 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1887 ![]() ![]() |
I think that could be as simple as fuse #3 - 15A. It covers most of those things that are gone, and none of the things that are still going.
Above the transmission tunnel, upper row, third from the left. Worth a try anyway. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Thank you. I have forwarded on your suggestion to my daughter. Everything was working when she parked up and did not work when she restarted. So a fuse would fit the bill..hopefully. 1982 88" 2.25 diesel
Bang on the button, all sorted now! ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
My thoughts exactly but according to my daughter everything is fine so far. The only time I had bother with fuses blowing on the Puma was when I borrowed a trailer. When I plugged it into the Puma it blew one of the fuses so the trailer lighting had a fault. My daughter does have a horsebox but up to now has had now bother when towing. Anyway if it goes again I told her to have it checked out. 1982 88" 2.25 diesel
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
Trailer socket is a good call. I had the indicator switch dropping apart inside and causing a short. If she has problems with indicators staying on it will need taking down and rebuilding. 1995 Defender 110 CSW
1971 SIIA Lightweight |
