Home > Puma (Tdci) > Front prop into transfer box |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3220 |
Part 5 and 11.
https://www.lrworkshop.com/diagrams/land-r...ge_53743#5 What I am not sure of is if it can be done in situ as there is the center diff locking ring on the front output shaft. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
26th Jul 2021 5:19pm |
Btw, how much is 'some' play? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
26th Jul 2021 5:20pm |
Ijk10 Member Since: 01 Apr 2021 Location: Newport Posts: 37 |
Thanks for the reply...
I was checking the uj and could feel and as the play where it enters the transfer box...i would imagine there should be no play at all in this area..and there is a definite clunk from this area.. |
26th Jul 2021 6:12pm |
My old 90 had a very small amount of movement if I grab the front prop shaft and rock it up and down. Never gave any issues though. Unsure if play there can cause a clunk. But good to check the nut on the output flange. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
26th Jul 2021 6:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7722 |
Rotational play or linear? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
26th Jul 2021 8:04pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2560 |
A small amount of radial play is normal as it’s a ball bearing not a taper roller. If it’s not leaking or rough to rotate then it will be fine.
26th Jul 2021 9:29pm |
Linear play... |
26th Jul 2021 10:18pm |
It's not leaking but there is some movement |
26th Jul 2021 10:19pm |
