Home > Puma (Tdci) > Front prop into transfer box
Ijk10
Wales 2007 Defender 110 Puma 2.4 CSW Keswick Green
Hi all
Hoping for some advice on how to fix this issue.
There is play in the part the front prop goes into the transfer box.
Is it a simple bearing and seal replacement?
Post #914096 26th Jul 2021 1:43pm
Dinnu
Part 5 and 11.
https://www.lrworkshop.com/diagrams/land-r...ge_53743#5
What I am not sure of is if it can be done in situ as there is the center diff locking ring on the front output shaft. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #914122 26th Jul 2021 5:19pm
Dinnu
Btw, how much is 'some' play? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #914123 26th Jul 2021 5:20pm
Ijk10
Thanks for the reply...
I was checking the uj and could feel and as the play where it enters the transfer box...i would imagine there should be no play at all in this area..and there is a definite clunk from this area..
Post #914126 26th Jul 2021 6:12pm
Dinnu
My old 90 had a very small amount of movement if I grab the front prop shaft and rock it up and down. Never gave any issues though. Unsure if play there can cause a clunk. But good to check the nut on the output flange. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #914129 26th Jul 2021 6:26pm
jst
Rotational play or linear? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #914147 26th Jul 2021 8:04pm
Retroanaconda
A small amount of radial play is normal as it’s a ball bearing not a taper roller. If it’s not leaking or rough to rotate then it will be fine.
Post #914163 26th Jul 2021 9:29pm
Ijk10
Linear play...
Post #914178 26th Jul 2021 10:18pm
Ijk10
It's not leaking but there is some movement
Post #914179 26th Jul 2021 10:19pm
