![]() | Home > Puma (Tdci) > Indicators and hazards not working |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
https://www.defender2.net/forum/post853783.html#853783
Jgh112 Member Since: 12 Jul 2021 Location: Devon Posts: 20 ![]() ![]() ![]() |
is it best to replace the switch with something like this?
That's the original switch, but given the cost I would do some investigation first.
I would bridge the pins 1 and 3 on the hazard switch connector, then turn on ignition and see if the indicators work. And/or bridge pins 2 and 3 (PURPLE/BROWN to LIGHT GREEN), this should instantly bring on the hazards. If neither work then either BOTH fuses 21 and 31 in the fuse box above the pedals have blown, or the flasher unit is playing up. ![]() ![]() |
