Home > Puma (Tdci) > Indicators and hazards not working
Jgh112
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Blenheim Silver
Hi guys,
I am in the middle of swapping out the led lights for halogens however my indicators and hazard lights arent working.
When I unlock and lock the car the indicators flash and the arrows flash on the instrument cluster but the stalk and hazard switch don't operate the lights or lights on the cluster at all.
I have ordered a new flasher unit as because I have changed the lights back to halogens, the led adjustable flasher unit may not be helping so will fit that. If that doesn't fix it will it be the hazard switch? If so where is this located and how do you fix it, do you replace the whole switch, because have looked online and they are £50 for genuine.
Appreciate the help.
Post #913547 22nd Jul 2021 10:12am
Martin
Site Admin
https://www.defender2.net/forum/post853783.html#853783  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #913549 22nd Jul 2021 10:16am
Jgh112
is it best to replace the switch with something like this?
Post #913550 22nd Jul 2021 10:21am
Martin
Site Admin
That's the original switch, but given the cost I would do some investigation first.
I would bridge the pins 1 and 3 on the hazard switch connector, then turn on ignition and see if the indicators work.
And/or bridge pins 2 and 3 (PURPLE/BROWN to LIGHT GREEN), this should instantly bring on the hazards.
If neither work then either BOTH fuses 21 and 31 in the fuse box above the pedals have blown, or the flasher unit is playing up.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #913555 22nd Jul 2021 11:15am
