![]() | Home > In Car Electronics > RAM X-Grip mount on Puma dash |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 632 ![]() |
Hi folks. I've recently bought a RAM X-grip mount and just need to buy the ball and the arm.
I'm looking at the "ram defender dashboard mount" from MUDUK - its just a ball that is mounted through one of the existing dashboard screws. see here https://www.mudstuff.co.uk/collections/ram...oard-mount The listing screw I'm interested in replacing is the central mount above the clock - as this mimics the factory Garmin GPS position. This is listed as one of the options on the MUD website. Only, its the one position that I can't find any photos of - has anyone mounted a RAM mount in this position? If so have could you let me know if there is plenty of clearance for the arm and what length of arm you chose? I'd also be curious as to how solid the mounts are in these locations - I don't know what the dash screws into - so not sure if its a plastic plugsert or a rivet on a tab, guess I'll find out. |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
The grab handle and clock assembly bolts into the metal bar which runs across the entire dash area.
![]() Click image to enlarge These are the only 4 points that the plastic dash attaches to this bar, the rest of the fixings are capture type receiver plates with strategic tabs and not really designed for any load on them. ![]() Click image to enlarge Nothing stopping you removing the dash and fixing a plate to the bulkhead, however you have a lot going on behind there with the wiper set up The reason the RAM mount for attaching to the grab handle area is at that location is because that's the point in which the weight can be held safely. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3769 ![]() ![]() ![]() |
I can confirm that there is ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
If it is of any interest, I currently have RAM balls fitted to the grab handle fixing screw nearest the centre of the vehicle (used for a 10" tablet running Memory Map), both of the heater panel lower fixing screws (one for smartphone, one for a reversing camera screen), the former rear view mirror mount (I don't have an interior mirror, and the ball mount is not currently in use), and the front mount of the passenger seat runner nearest the vehicle centre line (screen for a reversing camera on the rear of my big IW trailer).
So in total at the moment I have five RAM balls fitted, four of them in use. That's a whole load of balls! |
I've just got a regular suction mount in that area and it works fine. I probably have to reattach it twice a year? Something like that, it's not particularly significant.
I used to have it on the right of the steering wheel however had phone overheating issues and was concerned about it falling out the window. In the middle it's got the vent blowing on it and it's unlikely to fall out! |
Thanks very much guys - I'll keep having a poke around and may have a punt by buying one to see where i seems most at home.
siglo Member Since: 07 Aug 2015 Location: Kuwait Posts: 50 ![]() ![]() ![]() |
I used the LR sat nav mount for a while to mount a heavy garmin unit on it. It broke, twice, so I mounted a RAM mount on it and I am happy with the results. The LR mount comes with a metal plate that you install underneath the dash with adhesive tape and the mount screws into it. It it quite sturdy and has been working fine for me with no issues.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Hi all.
I took a chance and ordered a MUD RAM mount. It does actually fit in that middle front screwhole with plenty of space between it and the screen. The issue is that it fits too well and sits quite low - loo low to get an arm on it I think (I have the ram x-grip and now the MUD mount, but haven't got an arm yet to try). I suspect I'll need to machine a collar in order to space it sufficiently out of the recess in the Puma dashboard to make it usable, but will report back |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
I've got a few different RAM mounts primarily for phones as a cheapo Halfords style mobile phone holder is completely inadequate on rough roads here.
I fitted the screw-in balls in both the 300 and the Puma into the specified locations on top of the dash, but they are actually not that rigid in either vehicle as what they screw into is not solid, and I also found that it meant the phone wasn't quite where I wanted it. I've ended up settling on using the RAM suction mounts onto the windscreen which are much better (and of course will fit anything at all and can be located exactly where you want them). --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Ngala Member Since: 26 Oct 2020 Location: Germany Posts: 5 ![]() |
Gasket, I am trying to do the same thing. What did you end up doing? I am hoping to use the center dash screw at the windshield. Cheers |
Hi - I didn't fit it in the end.
I tried the mount in the position described above and it looked and fitted fantastic. Its as if Land Rover intended a RAM ball to be fitted there. But... as others had forecasted, the mount is simply a plasic plug and I wasn't satisfied with it being sturdy enough to securely hold my phone on the end of an arm. So I scrapped the RAM plan. Instead, I simply bought: 1) a Brodit Pro Clip https://www.brodit.co.uk/brodit/vehicles/L...654077.htm and 2) a Scosche magnetic XL kit https://www.amazon.co.uk/Scosche-magicMOUN...B074K9VXV6 Stuck them together and voila! an absolutely rock solid phone mount, perfectly positioned. In fairness, it isn't my idea: in the US the Brodit proclips are often sold with Scosche mounts. |
