Home > Td5 > Intermittent Start
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Intermittent Start
Inconsistent start feels, probably luck based, alignment of stars and planets and sometimes having everything crossed.
Or alll of the above
So whats been replaced in the last 12months
Fuel Pump
Fuel Filter housing (Gore Machined one) and valves
FPR Gasket
Injector washer and seals (seat re-cut)
New starter motor
Crank Position Sensor
Last on the list is to check are earths and relays but I don't have RAVE or anything to check which relay is which could someone give me a hand with that please.
As I look into the drivers seatbox, From left to right I have two Yellow relays and one Black one, and thats all.
Don't know what else to consider... and yeah I've cleaned the ECU plugs as well as already replaced injector loom as well.
Cheers 4.0 V8 Defender 90
My Instagram
Post #912626 16th Jul 2021 7:51am
kenzle8a
battery?
Post #912629 16th Jul 2021 8:02am
LJMARSDEN
Sorry, Should have mentioned the battery is being charged fine 4.0 V8 Defender 90
My Instagram
Post #912632 16th Jul 2021 9:06am
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
you have might have already done this but its important that you have a really good earth so i would recheck and clean all the earth points. When it fails to start are you getting any clicking sounds from any of the relays under the drivers seat ? if so that could be there is a fault with the connectors that the relays plug into ?
Post #912648 16th Jul 2021 10:12am
geobloke
I have literally just been through this infuriating problem and diagnostic list of things to check.
Turned out to be the relays were just worn, see here:
https://www.defender2.net/forum/topic53859-180.html
Pull out the relays and open them up, check the contacts for pitting, charring and like in my glow plug relay smoke stains... Shocked
Since replacing the relays she has not failed to start. Although I now have bigger problems... Rolling Eyes
Post #912685 16th Jul 2021 2:53pm
LJMARSDEN
Thanks for the suggestions - I've just replaced all three relays with some generic ones that are the same AMps and voltage but still not luck.
I'll be checking and cleaing all earth points tomorrow. Thumbs Up Thumbs Up Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #912715 16th Jul 2021 6:29pm
LJMARSDEN
Yes all relays do click when I'm trying to start it and even the brand new ones
 4.0 V8 Defender 90
My Instagram
Post #912716 16th Jul 2021 6:31pm
dorsetsmith
2002 my TD5 defender wiring
https://1drv.ms/b/s!AtZSoWFHDgnGlGJ6dB05NJC8QFj9?e=OKJjbG
Is your engine cranking over ?
Is starter relay resaving 12v supply from fuse box ?
Post #912756 17th Jul 2021 8:51am
LJMARSDEN
Yeah the engine is crankning fine and battery is charging fine too, I'll have to check the relays
But, it looks like it more of a fueling issue as is struggles to catch but after let's say "sufficient" cranking it will start 4.0 V8 Defender 90
My Instagram
Post #912790 17th Jul 2021 3:40pm
landy andy
Try, for a while, always priming the fuel pump, before you attempt to start it. That may indicate that you are getting air into the system.
Post #912793 17th Jul 2021 3:57pm
LJMARSDEN
Yeah thats always been the process - I have a suspicion that it may be injector washer and seals again, A bit premature since they were already replaced just over a year ago.
I won't be removing those fora few days yet though. 4.0 V8 Defender 90
My Instagram
Post #912794 17th Jul 2021 4:09pm
LJMARSDEN
Forgot say thanks for the Electrical diagrams.... Could you tell I was in need of them with all this trouble I'm having Rolling with laughter 4.0 V8 Defender 90
My Instagram
Post #912796 17th Jul 2021 4:15pm
dorsetsmith
But, it looks like it more of a fuelling issue as is struggles to catch but after let's say "sufficient" cranking it will start
ok as landy andy
priming mod the fuel pump, with the fuel pump running press accelerator pedal five times you see amber engine lamp on the dash flash and fuel pump start and stop 4 times
when i have fitted new injector seal and copper washer in the past i fund that having priming fuel system 2 or 3 times the engine still will not fire up (air lock in the injectors stopping the fuelling )
you may also need to floor accelerator pedal when starting the engine this give long PWM to the injectors
also Landy Andy air in fuel system have look at your fuel filter head can be problem and also ( air bleed valve and duck bill nonreturn valve letting fuel dram back from head
Post #912797 17th Jul 2021 4:30pm
landy andy
We’re Land Rover parts used?
I’ve read about other makes not working well, or for long.
Post #912810 17th Jul 2021 5:21pm
LJMARSDEN
The airbleed and one way we're just items from an eBay store, I might replace them with genuine however the airbleed is quite Censored up with debris so it seems either the washers are gone or maybe some corrosion on the tank side of things 4.0 V8 Defender 90
My Instagram
Post #912969 18th Jul 2021 8:38pm
