Home > Maintenance & Modifications > How do you fit hinges without chipping the paint?
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
I'm wondering if there's a trick I'm missing.
I've just had to change my drivers door hinges.
I carefully keyed, primed, painted and clear coated them to prevent future rust as you do.
Whilst fitting them, when inserting and tightening new shiny stainless bolts I have of course chipped them down to bare metal in a few small areas around the bolt heads. (Not helped by having to tighten and re-loosen a bit to align door)
So how do I avoid this? Some trick with masking tape?
Was my clear coat just not good enough?
Am I just clumsy?
Post #912282 13th Jul 2021 11:20pm
Dinnu
I think this is normal, but is more likely to happen if paint is applied on the thick side. With genuine bolts, I even had the head scraping on the side of the counter bores.
For my restoration I am also using stainless steel (reworked standard panheads) which I undersized the head on a lathe for this specific reason. I have also rounded a bit the edges. I have painted the hinges quite a while back so very sure that the paint reaches maximum hardness. I plan to put some grease so the bolts can ‘slide’ in the paint a little more free. But I will be fingers crossed when installing the doors. I have placed some pictures of the bolts on pg6 of my restoration thread.
https://www.defender2.net/forum/topic72365-75.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #912290 14th Jul 2021 5:50am
