Home > Puma (Tdci) > Switched live pickup
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Going to be fitting a temperature gauge for external temperature on our 110 2.2. I’m full on the aux board I’ve put in so was looking to pull power from behind the dash for the gauge as it’s only 2 Amps.
Is there anything obvious? I know 33/34/35 in the fuse box is switched…. Thoughts?
Post #909996 29th Jun 2021 4:14pm
Bluest
Cig lighter would be obvious choice for me 2007 110 TDCi Station Wagon XS
Post #909998 29th Jun 2021 4:52pm
Matt110
That bluesea unit from the other thread on temp sensors (which I've now reluctantly had to add to my own rather long list!) Rolling with laughter you could just swap out for the cig lighter socket and it would only be on with ignition?
I guess if depends if you use the cig lighter socket.
Post #910006 29th Jun 2021 5:36pm
hank
Make up or buy a piggyback connector for the cigar lighter - see here https://www.defender2.net/forum/topic78703.html > 110 XS Double Cab
Post #910009 29th Jun 2021 5:51pm
Timcat
Many thanks Gent’s, the Cigarette switched feed it is. Due to a twist of fate I’m now going with the Bluesea temp gauge & as Harry has suggested I may just remove it due to the fact we have an additional 3 sockets on the central cubby.
Post #910023 29th Jun 2021 7:22pm
