Home > In Car Electronics > TD5 Cigar lighter piggy back connector
ijefferyes
United Kingdom 2002 Defender 90 2.5 TD CSW Zambezi Silver
Can anyone tell me where I can buy the two connectors that go on the back of the cigar lighter in a TD5?
I am wanting to make a piggy back connector, so I can wire in some USB sockets.
Yes I know I could probably just use spade connectors, but wanted to try something more secure.
Wiring diagram shows C0074 and C0089. I think the L shaped plug could be YPC109020, but can't find that anywhere.
Post #905035 25th May 2021 11:48pm
Mo Murphy
Or for a very small extra bit of work you could put in a fused supply direct from the battery for your usb sockets and do it properly.
A few feet of twin core and an inline fuse holder and you are sorted 🙂👍
Of course, theres always scotchloks if you want to be hardcore ! 🥴
50 Shades of Pennine Grey
Post #905057 26th May 2021 9:28am
ijefferyes
I have purchased the USB socket from MUD
https://www.mudstuff.co.uk/products/mud-land-rover-usb-socket
They already have a fuse in the wiring, so that is already covered. Was then just looking for the closest power source, which seemed to be the cigar lighter.
Post #905058 26th May 2021 9:30am
Martin
Site Admin
I've got them, I use them to make these (D3 heated wheel retrofit loom):
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #905060 26th May 2021 9:35am
hank
I bought a couple to do the same but despite scouring my emails I cannot find the order details! I may have bought them from Martin on this site.
Pretty sure these are the ones? Contact Martin he will sort you out.
https://kojaycat.co.uk/6mm-2-Way-12v-T-Aut...r-in-White
https://www.ebay.co.uk/itm/323741937422
Alternatively do you need to retain the cigar lighter/socket? If not have you considered one of these?
 > 110 XS Double Cab
Post #905061 26th May 2021 9:40am
rallysteve
https://www.polevolt.co.uk/acatalog/Mulitple_Connectors.html
See the two-way t-shape version on there
Post #905062 26th May 2021 9:40am
ijefferyes
I think I will just stick to the OEM look of the MUD USB plugs.
As I say just need to wire them in.
Post #905074 26th May 2021 11:13am
hank
Fair enough. If you find the illumination too bright on them refer to this post
https://www.defender2.net/forum/topic75987.html?start=21 > 110 XS Double Cab
Post #905078 26th May 2021 11:33am
ijefferyes
Thanks for the tip! Hadn't got that far yet, but I am sure it would have bugged me.
Have already changed the colour on the radio to match the Defender green Laughing
Martin is also sorting me out with a wiring loom, to fit the back of the cigar lighter. That saves me that job!
Post #905080 26th May 2021 11:54am
ijefferyes
A thing of beauty, all ready to be installed.
Post #905731 30th May 2021 1:46pm
kmac
Looks awesome, how much was it please?
Post #905807 31st May 2021 8:52am
ijefferyes
Martin provided me with the piggy back connector for the cigar lighter, this just came with two wires hanging off. I will let him comment on the price for this.
I then had to do the soldering to join the plugs from the mud kit. Then, I also used a piggy back spade connector and some 200K resistors to reduce the brightness. As I didn't have either the piggy back spade connector, the shrink wrap sleeves nor the resistors, these cost me about £15 in total from Amazon, but now I have lots spare.
Fitted today.
Post #905879 31st May 2021 8:00pm
