Page 1317 of 1392 <123 ... 131613171318 ... 139013911392>
mk1collector
Do you have a link to the outlet? And where did you get the pipe from?
Ray Ray
My build thread
Post #908381 18th Jun 2021 12:56am
kenzle8a
Heres all the bits I used. Most of the inspiration was from Graftys thread a while back.
Theres some trimming of the ducts and joiners required, also the airbox intlet needs cut closer to the top, I scribed mine with a vernier calliper at the required hose ID.
Duct ( I got 2 meters of 102mm) to be safe.
https://www.autosiliconehoses.com/silicone...e-red.html
Duct to Silicone joiner (I used the 102mm ID / 50m length).
https://www.autosiliconehoses.com/alloy-ho...-tube.html
Reducer to airbox (I cut the airbox inlet at 90mm up the pipe a bit). I used the 102mm to 90mm pipe.
Wing to Duct Plate (its the metal wall plate, you have to buy 2 but its only £10)
https://www.ebay.co.uk/itm/182591916160?var=485158745811
And the Louvers incase anyone wants them are from Paddocks, they do the wing tops as well. I sprayed mine black with VHT caliper paint as its what I had to hand.
https://www.paddockspares.com/pm757r-stain...ke-rh.html
Post #908405 18th Jun 2021 10:17am
mk1collector
Perfect thanks Thumbs Up Ray
My build thread
Post #908455 18th Jun 2021 5:44pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
At the age of 55 I have today committed a major sin, as a fully paid up member of the caravan hater society, today I towed a work mates caravan from Pembrokeshire to Llanidloes, through some pretty narrow Welsh roads.
Having never towed a caravan before, but pretty experienced towing a large trailer, the stress of towing a mates pride and joy made it quite an experience.
I think I will stick to my demountable camper.
 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #908470 18th Jun 2021 7:53pm
L110CDL
With this sunny weather lasting, i have been making good use of these
It's very flapalicious Cool Clayton.
Keeper.
Post #908476 18th Jun 2021 8:59pm
seriesonenut
flaptastic Laughing 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
1990 Defender 200tdi CSW (sold)
1989 Land Rover Ninety (sold)
1998 Discovery 2 (sold)
1995 Discovery 1 (auto) (sold)
1990 Discovery 200tdi (sold)
1987 One Ten CSW turbo diesel (sold)
Post #908482 18th Jun 2021 9:10pm
L110CDL
Laughing Clayton.
Keeper.
Post #908484 18th Jun 2021 9:16pm
excossack
Finally got around to doing some painting on the 110.
The fuel tank guard was looking particularly scabby.
Started off with removing the rear ARB as that was in need of attention, two bolts needed attacking with the angle grinder.
A good scraping back to remove old under seal, a degrease and a lick of Corroless rust killer to hopefully keep the rust at bay.
I will do a 2nd coat during the week.
Ordered new ARB clamps and bushes as now is a good time.
Decisions on ARB, do I rub back and paint. Get it powder coated ?
Or replace with one in a better condition?
While I was under the car the I found the exhaust hanger had snapped the weld from the exhaust causing a knocking and notice the rear mud flap to wheel arch panel was loose and then found the spare wheel carrier to door bolts also a bit slack, so tweaked them as well! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #908649 20th Jun 2021 7:55pm
Dinnu
Early morning pic... pulling a 2.5t weight, over 45ft total length.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #908968 22nd Jun 2021 5:15pm
AndyS
Fitted a new turbo hose which is just two screws but I'm still dead chuffed of myself. In this round of maintenance I've also fitted a new relay (more complicated than I thought), a new clutch switch and a new VCV valve (I know that's a double V but I don't care Smile ). The car is completely different to drive, you don't realise how they degrade when you drive them every day and you just adapt to it. But when they're working they're pretty good and fun to drive. Thumbs Up
Thanks to everyone on this forum who've helped me sort this stuff, it's absolutely totally invaluable.
Post #909274 24th Jun 2021 12:29pm
seriesonenut
got ready for a bit of a road trip starting tomorrow, a bit of a workout for both starting with a 300 mile run
ld2 by Richard Holmes, on Flickr
ld1 by Richard Holmes, on Flickr 1984 One-Ten CSW
2010 XS USW (sold)
Post #909326 24th Jun 2021 7:59pm
Terryt
Last large bit of the camper build arrived today ..Thanks to Fatcat 4x4 .. not only did he do us a great deal he personally delivered them from Somerset to Cornwall..can’t beat that sort of service I have to say ..
Post #909432 25th Jun 2021 4:47pm
Well that's not going to fall off the trailer.... Thumbs Up
Post #909446 25th Jun 2021 5:33pm
Do they open 100%?
Post #909448 25th Jun 2021 5:39pm
L110CDL
Yes they do Supacat Very Happy Clayton.
Keeper.
Post #909481 25th Jun 2021 8:32pm
